Kflop for 3d printing - Page 4
Page 4 of 4 FirstFirst 1234
Results 37 to 47 of 47
Thread: Kflop for 3d printing
  1. #37
    Aug 2015
    Default Re: Kflop for 3d printing
    Hey Tom,
    Thank you so much in advance for everything. You have helped me so much! Now I'm are trying to run a C-script along with the G-Code. I saw in the "Tool setup screen" an action type called "Execute Prog" which seems like it might help me accomplish what I want. I'm just a little confused about how to trigger this action and what is the purpose of the Persist Variable. For example, if I modify the M100 button so that it uses this action, will I call it by writing M100 followed by the Persist Variable in the G-Code reader? Is the Persist Variable a number (from 1-99) that I would be writing after the M100 command so that it knows it has to run the C-script? Or would KMotion know that it needs to run the C-script based on the M100 command alone? I'm really sorry for the bother, but I just want to make sure that I truly understand what's happening here.
    Thanks,
    Joanel
  2. #38
    Gold Member TomKerekes's Avatar
    May 2006
    Hi Joanel,
    The "Var" setting allows for a mechanism for the Host Program to send some data to a KFLOP C Program. For example the "S" command will set the Speed in RPM as a floating point value into the specified persist Variable.
    If you are simply coding "M100" then there is no related data so KMotionCNC just sets the M Code Index into the specified Persist Variable. This can be useful to have a single C Program handle multiple M Codes (or button actions) because it can determine from the variable what Action invoked the program. If you don't need to know the MCode index just make sure the Var setting points to a variable that is not used by something else.
    There is also an option to pass GCode Parameters P Q R into 1-3 consecutive persist variables starting with the specified persist variable. See the help page here:
    MCodes with Parameters
    HTH
    Regards
    TK
    http://dynomotion.com
  3. #39
    Aug 2015
    Quote Originally Posted by TomKerekes View Post
    Hi Joanel,
    HTH
    Regards
    Hello Tom,
    Thank you so much for everything. We were able to make it work with no inconvenience and everything ran smoothly. I have a different question though. Is there a way to control the KFlop and KStep with MATLAB? I introduced the KFlop and KStep to a friend of mine and he loved it. He has a setup running with MATLAB and he would like to run some stepper motors with his setup. Do we have to call the C functions through MATLAB? or is there another way to do it. Sorry for the inconvenience and thank you in advance.
    Thanks,
    Joanel
  4. #40
    May 2006
    Hi Joanel,
    Thanks for the feedback.
    I'm not familiar with MATLAB and I don't have a copy. But Googling shows that it supports any .NET interface so it should be fairly simple. See here for an example:
    https://www.mathworks.com/help/matla...-assembly.html
    Our .NET assembly is called KMotion_dotNet.dll
    HTH
    Regards
    TK
  5. #41
    Aug 2015
    Hi Joanel,
    HTH
    Regards
    HelloTom,
    Thanks! This is what I needed. I didn't think it was going to be that simple. I talked to my friend about it and he said that he will buy a KFlop and a KStep to start playing with them. Like always, thank you so much for your help and I'll let you know if I have other concerns.
    Regards,
    Joanel
  6. #42
    May 2006
    Hi Joanel,
    If your friend is successful please suggest he posts a simple example of what it took to interface.KFLOP to MATLAB.
    Thanks!
    TK
  7. #43
    Aug 2015
    Hi Joanel, If your friend is successful please suggest he posts a simple example of what it took to interface.KFLOP to MATLAB. Thanks!
    Hey tom,
    OF course! He looked at it and said that it should be easy to interface KFLOP with MATLAB, so I'll post an example as soon as he confirms that is perfectly working.
    Sorry for the inconvenience, but I have another questions. I made a control box for all the components that I'm using, but after wiring it for some reason my y-axis (channel 1) is not working properly. All the other axises seem to be working fine, but the motor connected to channel 1 can't move the structure. You can hear the motor runing, but the axis doesn't move. I thought it was the motor, so I swapped the motors between channel 0 and channel 1 and it was still doing it with the x-axis motor. I thought it was due to the soldering that I had done between the wire and the pannel connector, but I changed those with the wires from another axis and it was still hapening. I'm thinking that it might be the KStep, but I'm not completely sure. I haven't been able to test it further yet, but what do you think that might be causing the problem? I might have an idea of what it might be, but I wanted to ask you first since you have way more experience than me.
    Also, is there a way to make the y-axis work with channels 3-7? I tried adjusting the parameters in the "config & Flash screen" for channel 4 so that it works with the y-axis, but it wasn't working when I tried testing it on the "Step Response" window. I looked through the documentation for the KStep, but I couldn't find anything suggesting that you can do so. I'm really sorry for asking all these questions and thank you so much for everything.
    Thanks,
    Joanel Vasquez
  8. #44
    May 2006
    Hi Joanel,
    If the stepping motor just vibrates and doesn't move then usually only one of the two coils are being driven properly. You might power down and use an ohm meter right at KStep Outputs and check each output coil for the proper resistance. Also there should be no continuity (>100Kohms) from each coil to any of your grounds or to any of the other coils.
    The simplest way to change KFLOP Axis #1 to use Step/Dir generator #3 (to drive KStep Output #3). Would be to change the OutputChan0 parameter from 1 to 3.
    You might read this article:
    http://www.dynomotion.com/wiki/index...nnels_Channels
    HTH
    Regards
    TK
  9. #45
    Aug 2015
    Hi Joanel,
    Channels Channels Channels - Dynomotion
    HTH
    Regards
    HelloTom,
    Sorry for the late reply, but I couldn't work on my project until now. Happy New Year and I hope everything has been well with you. I tested J2 through J5 on both KSteps with a multi-meter:
    1- For the board that is giving me problems with the y-axis(J3), all the coils seem to display about 10.56 MOhms when tested between all of them, and with ground from J1 they displayed 0 MOhms,
    2- When I tested the second KStep, all the coils displayed about 6.4 MOhms when tested between all of them, and with ground from J1 they displayed about 3.3 MOhms.
    I don't know why the resistance is so different between the KSteps. I also checked the second board separately, and J3 is working perfectly fine, so I'm going to be using this board for my 4 main axis for now. If the resistance throughout the board were the same, then what could be the problem with J3 on the first KStep? It's really weird because all the other channels are working fine. I'm really sorry for all the inconvenience and thanks for everything.
    Thanks,'
    Joanel Vasquez
  10. #46
    May 2006
    Hi Joanel,
    I'm not sure what 0MOhms means. Is that what your meter reads for infinite ohms? Or is it a short 0 ohms? With your meter leads open and shorted what does your meter display? I suppose anything less than 500000 ohms might read 0 on a megohm scale. Open circuits can read various values caused by leakage, moisture, etc. That doesn't necessarily indicate a problem.
    I was intending for you to check with KStep connected to the motors (and with power off). Or on the connectors unplugged from KStep. That way the coils should read the motor coil resistance of maybe several ohms (whatever the Motor specs are). That would basically check the wiring and motor coils for continuity and shorts.
    It sounds like you measured KStep with the cables disconnected.
    I don't understand what you mean by 2nd board. Is that the "good" or "bad" board?
    Regards
    TK
  11. #47
    Aug 2015
    Hi Joanel,
    Regards
    HelloTom,
    I used a fluke 189 true rms multimeter (http://www.tmgtestequipment.com.au/s.../FLUKE_189.jpg) to measure the resistance. It ranges from 0 Ohms to 500 Megohms. I might have read it wrong and it probably was 0L, which does mean infinite ohms. I also shorted the leads and it displayed 0.0 Ohms.
    I checked the resistance with the motor connected and the resistance between A+ and A- was 2.4 ohms. The same for the resistance between B+ and B-. The resistance between all the other coils were about about 6.5 Megohms.
    Sorry for not being clear enough, but that's the good board. The second board that I checked was the good board. Sorry for the inconvenience!
    Thanks,
    Joanel Vasquez
