I decided to try switching the wires and repowering the mains. Doing this, no sparks. I did notice however that I couldn't see any supply voltage coming into side one of Snap Amp when viewing the Analog status screen. Switching the supply to side two, I could see that I was getting 80vdc. I'm guessing I fried something on side one. Hopefully this isn't the case. I tried tuning a DC servo from side two, but I couldn't get any motion. Nothing seemed to energize the motor. Using side two, I connected the motor + and - leads to outputs 4 and 5 (JP1 7-8). I downloaded settings to Kflop, set for DC Servo and output channel 10. The encoder is wired through Kanalog, and appears to be functioning properly (it is input 3 and set accordingly). With these settings the servos do not seem to be energized at all. Before trying to send signals to the motor, I made sure to set my peak voltage and current limits for snapamp. Am I missing something here, or is it safe to assume that the snapamp needs to be repaired?
