Newbie KFlopWebNC pause problem and sub-programs in Kmotion
Results 1 to 3 of 3
Thread: KFlopWebNC pause problem and sub-programs in Kmotion
    Jan 2015
    Default KFlopWebNC pause problem and sub-programs in Kmotion
    I just wanted to quickly ask if it was possible to call sub-programs (I need to call the sub routine from a different file) using the G-Code tab in KMotion. I am very inexperienced with G-Codes and I have just been trying to write a very basic G-Code that calls a sub-program a number of times and passes it a number. The sub-program performs a small task and then returns to the main file. I have searched and found numerous methods of calling sub-programs but none have functioned correctly whilst using KMotion and I think I must be missing something obvious.
    Thanks,
    Mike
    Gold Member TomKerekes's Avatar
    May 2006
    Default Re: KFlopWebNC pause problem and sub-programs in Kmotion
    Hi Mike,
    I couldn't duplicate the KFLOPWebNC Feedhold issue, but it looks like you removed that question so I assume it no longer is a problem. I would love to see your app.
    Regarding KMotionCNC Subroutines: unfortunately calls to other files are not supported. The subroutine must be within the same file. Here is the included SubroutineWithConditionals.ngc example which shows how to call a subroutine conditionally and multiple times.
    Code:
    G20
    #100 = 5
    (examples of logical operations)
    (result is 1 if condition is true)
    (result is 0 if condition is false)
    #101 = [#100 >  5]
    #102 = [#100 >= 5]
    #103 = [#100 <  5]
    #104 = [#100 <= 5]
    #105 = [#100 =  5]
    #106 = [#100 <> 5]
    (subroutine call can be looped a number of times)
    (the L or Q word may be used to specify the count)
    (if neither L or Q is specified a count of 1 is used)
    (if the count is 0 the subroutine will not be called at all)
    M98 P1 L3  (example using L to specify the loop count)
    M98 P1 Q3  (example using Q to specify the loop count)
    M98 P1 L#100  (example using a variable loop count)
    M98 P1 L[5 > 4]  (example using a conditional as a loop count)
    M2
    O1
    #200 = [#200+1]
    M99
    Regards
    TK
    http://dynomotion.com
    Jan 2015
    Thanks Tom,
    I isolated the feed hold issue but unfortunately I haven't solved it yet. If I remove all of the axis index checks in the InitAxis function I am able to feed hold correctly. Unfortunately this means I'm unable to load the axis data from the interpreter datafile. Any ideas?
    I have done a sneaky work around and I am currently using c to read through a file and perform the calls to g-code files, thanks for the update though.
    Regards,
    Mike
