Hi Troy,
I tried a number of things and I found something that looks promising. Simply feeding back a portion of the position error delayed by a fraction of the resonant oscillation period seems to be pretty effective. See this Video:
I used a size34 Stepper that had a pretty bad resonance when unloaded and unmounted on the table. The Resonance was at ~137Hz. It was excited the most when microstepping at 2200 microsteps/sec which is 137 Full Steps per second (KSTEP uses 16X microstepping)
Here is a Plot accelerating through the resonance (with no Damping)
Velocity Profile
Position error plot through resonance (no damping)
Position error plot at resonance (no damping)
Zoom in to measure resonant Frequency (~13.7 cycles over 0.1 seconds)
Position error plot through resonance (with damping)
Position error plot at resonance (with damping)
Here is the code I used. It is also attached as a text file.
Code:
#include "KMotionDef.h"
// Demo for testing Active Damping of Resonant Vibrations
// Technique used is to feed back a portion of the Position Error delayed in time.
// GAIN is the portion that is to be fed BACKLASH_OFF
// Freq and DELAY_CYCLE determines the amount of Time Delay
// (Typical vales are Freq = Resonant Frequency of system and 0.75 of a cycle)
// This program sets up a Servo Sample callback to perform the calculations.
// Note that once the program sets up variables and the callback it Terminates
// However the callback continues to execute. Downloading a new or modified
// program into the Thread space before stopping the Callback (UserCallBack = NULL)
// can cause a crash. The program is setup to toggle the Callback On and Off each
// time it is executed
// A circular buffer is used to delay the signal for a Freq=137Hz and Delay_Cycle=0.75
// the signal is delayed 61 Servo Samples
// The program also contains anti-dither code where below a certain speed (100uSteps/sec)
// for at least 0.03sec the Closed Loop and Damping Feedback is disabled
// The Damping can also be enabled and disabled by seatting/clearing persist variable 100
#define Freq 137.0 // Resonant Frequency to be supressed
#define DELAY_CYCLE 0.75 // Fraction of cycle to be delayed
#define GAIN 0.25f // portion of error to be fed back
#define MAXD 1024
int nDelay;
float Delay[MAXD];
float TimeDelay(float I);
void DoDither(CHAN *ch, float P_original, float P_low, float I_original, double *T0, double T1);
// Anti dither variables
double T1,T0_0=0;
float P_original_0;
float P_low_0;
float I_original_0;
// Called before every servo Sample
void CallBack(void)
// Compute Error and Time Delay it
ch0->DestOffset = TimeDelay(ch0->Dest-ch0->Position)*GAIN;
// Force no Damping if Stopped (Integrator off) or User on/off
if (ch0->I < 1e-6f || persist.UserData[100]==0.0) ch0->DestOffset=0.0;
// maintain Dither mode
T1=Time_sec(); // returns current time
DoDither(ch0, P_original_0, P_low_0, I_original_0, &T0_0, T1);
main()
int i;
for (i=0;i<MAXD;i++)Delay[i]=0.0f; // clear delay buffer
// Compute number of samples signal should be delayed
nDelay = (int)(DELAY_CYCLE*((1.0/Freq)/TIMEBASE)+0.5);
printf("nDelay = %d\n",nDelay);
// define Closed Loop PI parameters to be used while moving and when stopped
P_original_0 = 0.05;
P_low_0 = 0.0;
I_original_0 = 0.0008;
//Toggle Callback On and Off
if (UserCallBack)
printf("Callback Off\n");
UserCallBack = NULL; //Stop the callback
else
printf("Callback On\n");
UserCallBack = CallBack; // start the callback
// Performs Time Delay by saving New Value into a Circular
// buffer and retrieving older value delayed by nDelay samples
static int iDelay=0;
int i;
// Save new value
Delay[iDelay]=I;
// Get old value
i=iDelay++ - nDelay;
if (iDelay>=MAXD)iDelay=0;
if (i<0) i+=MAXD; // wrap?
return Delay[i];
#define SMALL_VEL 100 // step/sec
#define LONG_TIME 0.03
// Change Gains for one Axis Based on being nearly stopped for a least some period of time
if (fast_fabs(ch->last_vel) > SMALL_VEL) *T0=T1;
if (T1 - *T0 > LONG_TIME)// error for a long time
ch->P = P_low; // reduced gain
ch->I = 0.0; // no integrator
else
ch->P = P_original; // normal gain
ch->I = I_original; // normal integrator
Maybe you could give this a try. Let me know how much of it makes sense.
Regards
