Hi jossa,
Seems like you have success.
The next Step would be to test if you can get KSTEP to output an analog voltage. There is an example KStepPWMCorrected.c
Change the RefVoltage value to whatever voltage that you have applied to the KSTEP analog circuit (JP33 Pins 5 and 7). Change the V value to some voltage like 5. Run the program and check with a multimeter if the voltage on JP33 Pin6 relative to Pin7 is 5V.Code:#include "KMotionDef.h" #include "CorrectAnalogFunction.c" #define RefVoltage 11.09f main() { float V=5.0; FPGA(KAN_TRIG_REG)=4; // Mux PWM0 to JP7 Pin5 IO 44 for KSTEP SetBitDirection(44,1); // define bit as an output FPGA(IO_PWMS_PRESCALE) = 46; // divide clock by 46 (1.4 KHz) FPGA(IO_PWMS+1) = 1; // Enable FPGA(IO_PWMS) = CorrectAnalog(V/RefVoltage); // Set PWM }
