resolver and kflop - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: resolver and kflop
  1. #21
    Member TomKerekes's Avatar
    May 2006
    Default Re: resolver and kflop
    Hi RUSJIaN,
    Very good plots. Do you see how to calculate the Sine/Cosine Ratios now?
    But the amplitudes are low. Y is very low:
    50 / 2048 x 10V = 0.25V
    Is the Y Output voltage really that low?
    What are the time and voltage scales of your oscilloscope?
    It could be that we are sampling the ADC near the zero crossing of the signal. Sampling the signal near its peak will result in a higher resolution measurement.
    Do you have a dual trace scope to look at when the stimulus (SetBit/ClearBit) switches and the output signal at the same time? Or use the stimulus as a trigger?
    You might shift the phase angle of the stimulus forward to see if that helps. Move the SetBit and ClearBit up before one of the WaitNextTimeSlice(). That should be about a 180us shift in time.
    HTH
    Regards
    Does your
    Regards
    TK http://dynomotion.com
  2. #22
    Oct 2015
    Quote Originally Posted by TomKerekes View Post
    Hi RUSJIaN,
    #define RATIO0 (233.0f/312.0f) // size j/size k
    #define RATIO1 ----------------------------------------
    #define RATIO2 (222.0f/266.0f) // size p/size q
    time= 50 us/cell
    voltage=0.1 V/cell
    Resolver Y-axis actually defective. I put a spare motor on the axis Y, the problem disappeared. Now all axes give comparable data. I checked oscilloscope.
    No, my oscilloscope has only one channel.
    What concrete steps are taken to increase the resolution of measurements?
  3. #23
    May 2006
    Hi RUSJIaN,
    Your Ratios look correct.
    With the oscilloscope showing 0.26V and the ADC reading 0.25V the ADC sampling must be close to the peak. So that is good.
    I'm not sure what you can do to increase the resolution if you are sampling near the peak. What are the amplitudes of XYZ now?
    222 counts x 10V / 2048counts = 1.1V
    What does the scope show? You might increase the amplitude of the stimulus if the resolver can handle the voltage/current. Otherwise you would need to add an amplifier.
    I suspect the amplitude and resolution are enough. The resolution should be:
    222 * 2 * PI = 1400 "counts" per revolution.
    With a lead screw of 5mm pitch that would be 3.5um
    Does it all work acceptably?
    Regards
    Regards
  4. #24
    Oct 2015
    Hi Tom.
    In the past, the code had two consecutive command WaitNextTimeSlice (). When JOG command to position all axes added 490 pulses, but at the end of the movement 490 pulses also removed. As a result, the axis jerk.
    Now I have added code three consecutive command WaitNextTimeSlice ().
    Now, when the command added JOG 3-10 pulses, that is acceptable.
    As this change has affected RATIO all axes, now their size reaches about 1000 which will increase the accuracy of movements, it is now the maximum error is 30 pulses. Lead screw of 10 mm, one turn of 5000 pulses (resolver is connected via a multiplier of 1: 5) => error is 0.06 mm, it is enough.
  5. #25
    May 2006
    Hi RUSJIaN,
    I believe you are saying it is working. Congratulations!
    Happy Holidays
    Regards
resolver and kflop
resolver and kflop
