KFLOP Not Recognized by USB.... - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 19 of 19
Thread: KFLOP Not Recognized by USB....
  1. #13
    Mar 2007
    Hey Tom,
    Yea, I was pretty certain the USB chip had gone South, it just happened so suddenly, but your explanation/resolution absolutely point to a simpler, self-inflicted problem. Thank you for the great support and very quick turn-around! Needless to say I am a big fan of your products, I will do what I can to continue to help people discover how great they are.
    Hunter
  2. #14
    Jan 2013
    Default Re: KFLOP Not Recognized by USB....
    Hello Tom, I have the similar issue, but my computer doesnt recognise kflop at all.
    When I start Mach3 I get the message: "Dynomotion board not detected"
    I tryed to restart windows, windows recovery but nothing helped.
    I tryed to clean the board with acetone but no luck.
    I noticed when I plug in the USB the FTDI chip gets hot after few seconds.
    Is that normal or do you think the FTDI is bad?
    The 2 green Leds are working.
    Thank you.
  3. #15
    Gold Member TomKerekes's Avatar
    May 2006
    Hi mlinkadelsol,
    The FTDI chip U10 should not run hot. It is most likely damaged.
    You might check in Window's Device Manager. If the USB is working when connected something should show up.
    Regards
    TK
    http://dynomotion.com
  4. #16
    Jan 2013
    Quote Originally Posted by TomKerekes View Post
    Hi mlinkadelsol,
    Regards
    Hello Tom, a friend owning Local computer service swapped the FTDI chip with new one and now the computer recognise it as USB serial port (COM12) in device manager but when I run MACH3 it still says DynoMotion Board Not Detected.
    Is there any other thing I can try?
    (I forgot to mention that the chip is not overheating anymore.)
    Thank you.
  5. #17
    May 2006
    Hi mlinkadelsol,
    The new FTDI chip will need to be programmed to be recognizable as a KFLOP. There is an FTDI Utility called FT_PROG.exe that can be obtained here:
    FTDI Utilities
    Use it to Scan for the Device, then Apply a Template (KFLOP.xml in the KMotion USB Drivers directory), then Program the device, then cycle port. It should then show up as a KFLOP in the Windows Device Manager.
    HTH
    Regards.
    TK
  6. #18
    Jan 2013
    Hi mlinkadelsol,
    FTDI Utilities
    HTH
    Regards.
    Wow, thnx. Ill give it a try, hopefully it was just the FTDI chip fault.
    Thnx. again for your support.
  7. #19
    Jan 2013
    Quote Originally Posted by mlinkadelsol View Post
    It worked Tom.
    Thank you so much for your support once again.
