KFLOP + C10 breakout board from Keiling
Results 1 to 13 of 13
Thread: KFLOP + C10 breakout board from Keiling
    Dec 2011
    Default KFLOP + C10 breakout board from Keiling
    Hi Everyone,
    Has anyone connected a KFLOP to a C10 breakout board?
    I've started my first CNC project (G0704) and have ordered a Keiling 3-axis stepper motor kit to go along with my newly ordered KFLOP.
    The kit came with the C10 breakout board which looks like a convenient way to hook up all the drives and sensors. However, the connection between the C10 and the Kflop is unclear to me as it appears to have two different ports (25pin Parallel -> 26pin IDE(?)
    Am I making things more complicated? Help!
    Thanks,
    Tim
    Dec 2011
    Member Need TECH Help!'s Avatar
    Dec 2007
    Hi Tim,
    Its not that bad, i first thought that also. Start with the KFLOP manual. Then start making a wiring diagram on paper or software. This helped me alot. This will also help Tom from Dynomotion, who provides great support.
    HTH,
    Troy
    www.tsjobshop.com, www.homecncstuff.elementfx.com
    Dec 2011
    Thanks for the encouragement and advice. Wiring diagram is a good idea.
    Member TomKerekes's Avatar
    May 2006
    Hi Tim,
    KFLOP's JP7 26 pin IDC Connector is not the same pinout as a PC Parallel port and there are more IO pins and so forth. If you just plug them together 1:1 you will cause damage. You will need a custom cable to connect to the C10.
    You might read FishForFun's post
    Regards
    Regards
    TK http://dynomotion.com
    Dec 2011
    Thanks Tom for the headsup. I've read the post several times and am slowly starting to understand. I followed Troy's advice to do a wiring diagram. Below/attached is an image of my IO map from C10 -> KFLOP or LPT -> IDE26
    Does it look alright or optimized? Not sure how to get full use of all the LPT I/O since there aren't the same number of +5V DIO on the KFLOP...
    Do all the inputs need +5V?
    Thanks,
    Tim
    Attached Thumbnails Attached Thumbnails KFLOP + C10 breakout board from Keiling-c10_kflop-io-map-jpg
    Last edited by timbochung; 08-10-2012 at 07:45 PM. Reason: Changing image link to and uploaded file
  7. #7
    May 2006
    Hi Tim,
    Nice diagram but no that isn't correct :}
    The 8 Step/Dir Signals must be connected to KFLOP (IO 8-15) JP7 pins 15-22. As those are Hardware Step/Dir Generators and must use specific pins. See here
    There are 18 Digital IO on KFLOP JP7 and 17 on a parallel port so you will have one KFLOP JP7 DIO unused.
    They are all +5V tolerant/compatable except IO44 and IO45 which are 3.3V. So use IO44 as an output and don't use IO45.
    You will also need a GND connection.
    HTH
    TK
    Regards
  8. #8
    Dec 2011
    Hi Tom,
    I've updated the wiring diagram. Does this look right?
    Thx,
    Tim
    Attached Thumbnails Attached Thumbnails KFLOP + C10 breakout board from Keiling-c10_kflop-io-map_rev-1-jpg
  9. #9
    May 2006
    Hi Tim,
    That looks correct to me.
    Regards
    Regards
  10. #10
    Dec 2011
    Phew - thanks!
  11. #11
    Member vikramsN's Avatar
    Jan 2021
    Default Re: KFLOP + C10 breakout board from Keiling
    I have made similar cable and connected to C10 card. But no movement. But if I connect KFLOP signal directly to drive, motor moves.
  12. #12
    Dec 2011
    Quote Originally Posted by vikramsN View Post
    Other than verifying the pinouts - could be something with the card?
  13. #13
    May 2006
    Hi Vikram,
    Check if your axes are configured for open collector or TTL mode. Should be TTL mode for the C10 with TTL inputs. ie OutputChan0=8. See here.
    Regards
