Velocity change while jogging?
Results 1 to 2 of 2
Thread: Velocity change while jogging?
    Jan 2012
    us
    Default Velocity change while jogging?
    I'd like to be able to change the jog speed while moving. Anybody know if this can be done? I am simply trying to control 2 axis speed and direction based on a digital 4 function joystick and 1 analog trigger. Direction works fine, speed works fine but cannot change on the fly. Using kflop + snapamp + kanalog
    Thanks, Shannon
    Member TomKerekes's Avatar
    May 2006
    Hi Shannon,
    I don't understand why that doesn't work for you. A Console Jog Command should perform a blended change from one velocity to another while honoring limited Acceleration and Jerk. You can test this by typing various Jog commands on the Console Screen and observe the effect. Try that and see if it blends properly.
    Regards
    Regards
    TK http://dynomotion.com
