Results 1 to 10 of 10
Thread: Screw Bellows for a DM2400
    Mar 2012
    Hi all,
    Being the new owner of a DM2400, I have the need to replace the screw protection bellows. I have been supprised to be unable to find any information concerning these. Someone besides me has to have had this problem.
    Any suggestions?
    Bo
    Tinkerer
    Nov 2009
    Have you called Roberto at Dyna Mechtronics. They have a few parts but only a few.
    Mar 2012
    Thanks for the reply,
    Yes, actually Roberto did reply, for which I was grateful.
    They do have them. That's the good part. If I understand him correctly (and I have sent him a request to confirm) they are $80 each. That's $480 just for the bellows on all the three screws. If I misunderstood him, I will gladly correct myself here.
    I have actually found a good price on custom made ones... if I want to buy 250. :-)
    Still searching for a good solution.
    Bo
    Tinkerer
    Nov 2009
    I didnt say they would be cheap! If you do buy the ones from DM they will most likely be old new stock. Probably dry rotted by this time. Enjoy the machine.
    Dec 2007
    It's bugged me for ages how the cheap Chinese machines all come with metres of the stuff, but I haven't been able to source similar bellows anywhere over here that even approaches a semi reasonable price! They seem very hard to get?
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Jan 2006
    Probably not what you'd consider cheap, but you can get anythign you need from these guys: Bellows | Rubber Bellow | Way Covers | Machine Bellows | Gortite | A&A Family
    Matt
    Mar 2012
    I have looked around there a bit. Has anyone used one of their bellows on a DM2400 and if so, which one?
    I can't be the only one that has a Dyna that had the bellows return to their primordial condition. (goo, actually).
    I have some marine bellows coming and have even considered making a mold and trying to cast some.
    Sorry, I just can't stomach $320 for 4.
    Bo
    Registered bozidar22's Avatar
    Feb 2010
    Here is a few pictures of some home made bellows I made. They are made from ripstop nylon coated with polyurathane. the stiffeners are also custom made . the cost in materals is about $10.00 to $15.00
    I have been thinking about making a u-tube how to vidieo, I will post i here when i finish it.
    Attached Thumbnails Attached Thumbnails Screw Bellows for a DM2400-encloseure3_034.jpg   Screw Bellows for a DM2400-encloseure3_035.jpg   Screw Bellows for a DM2400-encloseure3_038.jpg   Screw Bellows for a DM2400-encloseure3_037.jpg
    Jul 2007
    I have seen these on lathes, I have no idea how much they cost though: Spiroflex Products - constant force springs, extension springs, motor springs, ebrw springs, www.spiroflex.com (see the Lead Screw Guards section)
    bob
    Mar 2012
    Well, I have had at least some progress on the bellows issue.
    I got a bellows used for the steering cable on an outboard motor and I am modifying the mounts to accomodate the ends.
    So far, I have had to spin some adapters on the lathe. I have a bit more to do, but it looks promising. I will share the details after I figure out if it will actually work.
    Bo
    1. G0704 bellows
      By awetmore in forum Benchtop Machines
      Last Post: 12-22-2011, 02:20 PM
    2. X2 Bellows / lead screw cover after CNC conversion...
      By forrest39 in forum Benchtop Machines
      Last Post: 08-09-2010, 02:21 PM
    3. Rubber Bellows
      By sprintfan in forum DIY CNC Router Table Machines
      Last Post: 09-20-2009, 11:54 PM
    4. Bellows / Boots
      By justCNCit in forum Linear and Rotary Motion
      Last Post: 12-30-2008, 01:46 AM
    5. Where to buy Bellows for my NSK Ballscrews and THK Linear guides ?
      By Calico in forum DIY CNC Router Table Machines
      Last Post: 05-17-2005, 03:39 AM
