Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 01-25-2012, 10:01 AM
Shea al'Thor is on a distinguished road
Need help figuring out Dyna Myte 4400 mill
Hey all,
I have been attempting to work with a Dyna 4400 3 axis mill and I'm not having very good luck with it so far... I'm used to post processing from Pro Engineer or SolidWorks and then running G-code in all the cnc machines I've used so far and so the conversational programming of the Dyna Myte machines is really throwing me for a loop... If anyone knows of a cheep efective way of running G-code on the conversational Dyna Myte machines that would be a great help.
Thanks all,
Shea
Old 01-25-2012, 06:26 PM
Gold Member
Caprirs is on a distinguished road
The SKIP control will not accept any G/M codes, only the Dyna conversational code. The only way to use G/M codes is to remove the Dyna SKIP control and re-fit the machine with a different control.
Old 01-25-2012, 06:46 PM
How would I go about switching out the step controles for newer ones? And about how much would I be looking at spending on a project like this?
Thanks for the replays
Shea
Old 01-25-2012, 07:23 PM
Gold Member
The SKIP control uses stepper motors. There are other threads in this Dyna forum with users describing how they are converting their mills to use Mach controls. I have no idea on cost.
Old 01-25-2012, 10:33 PM
CNC Bill is on a distinguished road
Caprirs
So, what you are saying there is no Post processor to use with SKIP?
Old 01-25-2012, 10:59 PM
Gold Member
The post processor is just a converter that takes the tool paths created in the CAM software and outputs those moves into the text format the machine control can understand. There are numerous CAM companies who offer post processors that will output the motion code in the Dyna SKIP format.
The Dyna SKIP control does not use G/M codes but can be programmed using many of the commonly used CAM packages. The biggest disadvantage of the SKIP control is the 999 lines of code limtation.
Old 01-26-2012, 08:53 AM
So what are some of the CAD programs thati could use to post process for dyna skip?
Thanks for the info
Shea
Old 01-26-2012, 09:24 PM
Gold Member
I am pretty sure Mastercam, Surfcam, and Gibbs all have post processors that will convert their tool paths into the Dyna format. All are fairly high end professional packages. Without knowing your budget and intended use, it is impossible to make recommendations.
Old 01-27-2012, 12:56 PM
I have access to pro engineer, solidworks and mastercam. I'll go ahead and give mastercam a try then. I mostly work proE and I know that it gives a whole list of different posts for a large assortment of machines, but it doesn't label any of them :/ do you by chance know if mastercam is like this as well? And if so, do to know which post to use for the dyna 4400?
Thanks for all the answers
Shea
Old 01-27-2012, 11:20 PM
Gold Member
I am not familiar with Mastercam or ProE so I do not know what is available. Typically, post processors are labeled for specific machines and/or controls. Thus, a post might have in its description Dynamyte, Dynamechtronics, Dyna, etc. In many cases, the only way to determine what the output code will look like is to install the post processor and post some code to see what comes out.
Dyna machines also used Mitsubishi controls and Dyna's own PC based control which are different from the SKIP control.
  #11   Ban this user!
Old 01-28-2012, 12:28 AM
The dyna 4400 that I have is from somewhere around the late 80s I think. It has the programming board out in front of it (which is removable). I'm pretty sure it uses dyna step... I have the mastercam manual in front of me and it doesn't look like it says what it posts for anywhere... Hmm then again it's hard to figure out anything using this manual... The one for proE is way easier to understand.
Thanks for the input
Shea
Edit: I'll post up some pictures of the machine on Monday.
Old 01-28-2012, 09:03 AM
Gold Member
I was trying to say that finding a post for Dynamechtronics or Dynamyte may not be sufficiently descriptive as Dyna used several controls over the past decades. So the post processor will have to be for Dyna with SKIP instead of Dyna with 4M/PC or Dyna with Mitsubishi M3/M520.
Dyna Myte 4400 (and 4000) parts for sale mmedina Dyna Mechtronics 12 04-11-2012 01:59 PM
Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos ckm Knee Vertical Mills 190 02-18-2012 12:42 AM
Dyna Myte 4400 No.2 retrofit vintageracer Dyna Mechtronics 29 01-07-2012 07:58 PM
Need Help!- Help simplifying a Dyna Myte 4400 Shea al'Thor Knee Vertical Mills 4 09-17-2011 09:56 AM
Problem- Dyna Myte 4400 Mill echostar DynaCNC 3 06-30-2008 08:23 PM
