Results 1 to 6 of 6
Thread: WTB Dyna Myte 3000 Lathe and 2800 mill
    Feb 2008
    I am looking for a Dyna Myte DM3000 and a 2800 mill. Working machines or parts machines considered. Any leads appreciated.
    Thanks!!
    Jan 2012
    Dyna Myte 3000 lathe
    I have a Dyna myte 3000 lathe. It needs work. Some one blew out the control messing with the x axis resolver. It has a very heavy table with it. I can send pictures. It has been sitting a long time so there is stains on the ways. I will take 750.00 for it where is as is. I don't think it has ever been run. The machine with table I am guessing weighs 1500 pounds. I am in Eden Utah.
    Registered 2ferrous's Avatar
    Jul 2010
    Where are you located?
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300
    BobCad 16, 20, 24 and now V25
    Jan 2012
    Dyna myte 3000
    I am in Eden Utah. The machine with table weight i am guessing is 1500 lbs.
    Jul 2011
    Us
    Dynamyte 2800
    I have a Dynamyte 2800 for sale.
    We got it in with no history, and spent a while to get it running.
    It has an onboard PC running DOS and a proprietary 4M Program. The PC was in bad shape; it wouldn't boot properly. The hard drive it came with was failing, and after cloning it to a new drive the computer booted properly.
    It worked flawlessly the first times it turned on. We saw all the motors were functioning properly including the spindle. After a day or so it began to throw back error codes.
    I have since been unable to give any attention to it, but I am sure it's just a silly electrical short away from being a fully functional CNC mill.
    On a side note, I was hanging on to this machine because I believe it would be an excellent candidate to retrofit to LinuxCNC or a similar application.
    You can get back to me at vittorio.alfieri [at] alpha-logix.com
    EDIT: I am in Brownsville, Tx
    Dream outside the Box frog's Avatar
    Jun 2005
    I am also looking for a DYNA Myte 2800 if anybody knows of someone that has one that is a needing a retrofit. kd4ffd@yahoo.com
    1. Dyna Myte 2800
      By hectorja in forum Spanish CNCzone
      Last Post: 12-14-2011, 10:14 AM
    2. dyna myte 2800/3000 to greco systems
      By davidponte in forum Dyna Mechtronics
      Last Post: 11-13-2011, 07:52 PM
    3. dyna myte 3000 lathe
      Last Post: 04-15-2011, 12:02 PM
    4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
      By britcollector in forum Want To Buy...Need help!
      Last Post: 02-22-2010, 10:20 PM
    5. Need Help!- DYNA MYTE 3000 BENCH-TOP CNC MINI-LATHE
      By TitaniumCannons in forum Benchtop Machines
      Last Post: 12-10-2009, 12:30 AM
