Results 1 to 11 of 11
Thread: Need DM2800 Lambda LFS-44-48 power supply
    Apr 2010
    107 volts in, 0.0 volts out. This is the larger original power supply in a DM2800.
    Tinkerer
    Nov 2009
    Tim, when did you get a 2800? I am guessing it is a 48vdc power supply, what amperage? Swap it out for a Keling?
    Apr 2010
    It's 48V, 5Amp. I finally figured out I don't need an original and been looking at various power supplies on ebay; the Keling is one I'm considering but it looks exactly like some of the cheaper ones with a label pasted on. I'd rather spend some extra $$ on a better one, with a future upgrade in mind. I've spent a lot of time & effort getting the DNC & post processor working with SKIP & was playing with the touch probe (had it working) when the PS went out. Also picked up a rotary axis & want to get that working with the original control, but it's from a 2000/2400 so uses a different driver & a bit of a challenge.
    I've had the machine about a year, bought it on ebay, had it shipped, original owner wanted it back after they sold it. I like it, kind of getting used to the quirky nature of the control. Don't have much time to play with it, did some engraving, still on the skid it was shipped on. Can't convince the wife to give me time to pour the cement slab in my barn for it & other machines I've been collecting.
    Steve
    Tinkerer
    Nov 2009
    Thought this was Tim/aka 2ferrous.
    Apr 2010
    I've been told my Wisconsin accent sounds Canadian, must be coming thru in my posts, eh?
    Tinkerer
    Nov 2009
    Registered 2ferrous's Avatar
    Jul 2010
    Nope, not me. I'm sticking to the 2ferrous moniker.
    Have you tried Antek - Your reliable source of transformers, power supplies, and more.
    I use their power supplies for all my machines.
    Timothy
    Dyna Mechtronics DM4400, Bridgeport Discovery 300
    BobCad 16, 20, 24 and now V25
    Apr 2010
    Timothy,
    Thanks for the recommendation. They have quite the selection.
    I won a linear regulated power supply on ebay, 48V 17A, I know a bit large but should fit & medical grade. I'll give an update once it's installed. I hope that solves the problem...
    Oct 2004
    U.S.A.
    I replaced my power supply on my DYNA 2800 also. I purchase the supply from JAMECO, their part # 161796 @ 149.95 + shipping. Spec. +48@10.0 at 240vac;0-8.5A@115vac. Has been running 5 years now! david pontes
    Apr 2010
    Issue resolved
    Thanks for the suggestions, once I realized it was safe to use a different power supply that met the same specs and fit in the same space it was relatively easy to find one, however there are so many it was hard to choose.
    Anyway it's up and running.
    Apr 2010
    Replacement for the Lambda 48V Power Supply
    There is another used unit available on ebay, same as the one I purchased.
    I was very pleased with the qualily of the unit, mounted in the available space using existing brackets, easy hookups, exceeds the required specifications, retails for over $900 new. Buy-it-now for $75.
    Ebay auction ID 250898743385
    1. How'd you supply your power supply?
      By cnczane in forum DIY CNC Router Table Machines
      Last Post: 08-28-2011, 06:13 AM
    2. controller power supply 115/230v OK for Australian power?
      By Momill in forum Australia, New Zealand Club house
      Last Post: 07-07-2011, 12:06 PM
    3. Replies: 0
      Last Post: 03-22-2010, 02:40 PM
    4. 24 V Lambda Power supplies
      By Brian.Holiday in forum General Electronics Discussion
      Last Post: 01-27-2007, 05:54 PM
    5. Power Supply from a computer power supply
      By jmytyk in forum General Electronics Discussion
      Last Post: 01-11-2006, 03:56 PM
