Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 07-16-2011, 04:06 PM
mfgbydesign is on a distinguished road
Did my Dyna Myte explode?
DM2800 original controls, suddenly not working.
I was messing with the wiring on the touch probe, had it working but trying to get the LED to light by swapping some wires, might have crossed a couple bare wires or inadvertently grounded the hot (yes I had it plugged in at the time, but hey it's only 5 volts). I heard something "pop" and the pendant went blank. Off, on, nothing. Checked fuses that I could find (2 outside, 1 inside), all OK. There's so many boards in there I don't know where to start.
The motor fans and cabinet fans run, no lights anywhere inside. Spindle does not work. It is VERY humid here today. Bummer 'cause it WAS working so well.
ANY IDEAS? I know just enough about controls to be dangerous (obviously).
Old 07-17-2011, 07:01 AM
No 5V power
Looked at the schematic. distribution board driven by 5V power. located power bus, no 5V power. Looked for seperate 5V power supply, is it integrated with the Lambda power supply? Can I just apply 5V to the bus? How many amps?
Old 07-17-2011, 08:56 AM
Lambda ES-8-5
I traced the 5V feed back to the Lambda ES-8-5 DC power supply.
Found one on ebay.
Old 07-24-2011, 04:03 PM
DM2800 Transformer needed
Replaced the 5V power supply. No change. Finally figured out my transformer is only putting out 38 volts (supposed to be 115V).
Old 08-06-2011, 02:30 PM
Lambda LFS-44-48 needed
48V power supply has no output. Would like to find a direct replacement, otherwise it might be time for an UPGRADE.
Prior post about transformer was incorrect. I measured it wrong.
Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos ckm Knee Vertical Mills 190 02-18-2012 12:42 AM
Newbie- Dyna Myte DM2400 l5c2c7 Benchtop Machines 14 10-31-2010 08:50 AM
DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!! britcollector Want To Buy...Need help! 0 02-22-2010 09:20 PM
Need Help!- DYNA MYTE PARTS davidponte Want To Buy...Need help! 0 04-12-2008 07:28 PM
DYNA MYTE 2400 helfriwj Benchtop Machines 4 04-01-2008 10:45 PM
