Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
View Poll Results: What have I to do in order to solve the problem?
Repair the machine by myself 3 100.00%
Get your precious support 0 0%
Call someone else to repair it 0 0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 04-12-2011, 12:36 PM
TTS_GL is on a distinguished road
Talking NEED HELP!!!! DYNA MECHATRONICS DM4400: stepper errors
The first problem:
- the y axis doesn't work correctly. During the working cycle the program stops giving the message: stuck y
I've made these controls:
- I've swapped the stepper between the x and y axis
- I've swapped the motor/encoder between the x and y axis
- I've disconnected (only from a mechanical point of view) the y motor/encoder from the machine in order to verify if it is a mechanical problem
- the stop happens always when the y axis runs towards the rear of the machine
- the stop happens during the cycle: sometimes the machine makes 1, 2, 3 operations on the y axis and then stops
- the display on the APU unit during the stop makes a bad signalling on the LED 8, lighting in sequence 1 bar after each other representing a zero character
- I've made the test cycle checking
- checksum: A and B are ok. C: I've not found the EPROM with the reference value on the APU board
- motor check: ok
- initialization: ok (in the working condition and also after x and z driver disconnect)
Now the spindle, after some working hours, doesn’t stop and the machine seems to be in a waiting condition: in this case it’s necessary to power-off the machine. At the subsequent power-on and initialization the spindle doesn’t stop and we have to wait for the next day: it seems like an overheating of some component inside.
I’ve also analyzed (with a Tk oscilloscope) wave forms on the
- ext reset
- write
pin of y stepper. During the analysis I noticed that the “stuck y” error disappears: otherwise, changing the working program, the x and y steppers goes in error. The same result has been obtained connecting the “write” pin with the “GND” pin of the y stepper with a 1Mohm resistor.
In my opinion the cause of problems may reside into the
APU pn. DM 4X00 REV.3
Board.
Is there someone how is able to help me in repairing my machine?
Is there someone how owns an APU card to sell me?
Thank you very much for helping.
Giorgio Landi – Milan – Italy
Old 04-12-2011, 05:27 PM
Fastest1 is on a distinguished road
I do know in my experiences with my 2 Dynas, the limit switch being dirty always caused the stuck axis error. Disassemble the limit switch, clean it all out and reassemble. The other problems I dont know about. Where is 2ferrous?
Old 04-13-2011, 01:43 AM
Hi Fastest1,
thank you for your suggest: I'll try it as soon.
What do you mean for 2ferrous?
Old 04-13-2011, 06:42 AM
2ferrous is a member here, I believe he has a 4400 and has been running them for a few years. He did change his username at 1 time.
Old 04-13-2011, 06:54 AM
Great!!!
Thank you Fastest1: comparing your speed in answering to me, your name is slow!!!!!
Old 04-13-2011, 09:18 AM
Good to be fastest at something!
Old 04-13-2011, 07:44 PM
2ferrous's Avatar
2ferrous is on a distinguished road
I'm here! Yea!
And have 2 DM4400's
Dyna Mechtronics DM4400, Bridgeport Discovery 300
BobCad 16, 20 and now V24
Old 04-13-2011, 07:50 PM
2ferrous's Avatar
There is a way lube line that runs under the table to the carriage from the back of the machine through the column. Its spiral wrapped around the Y axis ball screw and because of its age, its most likely broken and leaking waylube into the trough under the covers. So that means no lube to the Y or X axis. The Y axis usually gets stuck first.
To check this line you have to remove the angled way cover attached to the back of the carriage and then a number of other covers and at least one oil line fitting. Its a pain in the arse. I put an old towel over the table so I could lean on it with out getting covered in coolant.
Timothy
Old 06-09-2011, 03:10 PM
Thumbs up Hi 2ferrous, nice to meet you
Hi 2ferrous,
I see that you have a deep knowledge of Dyne 4400 milling machine. Thank you for the answer and I'll check the way lube to the Y axes.
In any case, I'll tell you how my machine runs:
1) if you mill moving only along the Y axis the machine runs correctly
2) if you mill moving along X and Y axis the machine stops giving the message "stuck y" always at the same program step.
3) if you drill the problem is less evident
Do you know if there are lube sensors for the axis?
I've substituted all integrated circuits on the APU BOARD but the problem is always the same.
Thank you a lot for the help and I regret to have seen your answer only now.
Old 12-16-2011, 04:53 AM
JoseGarrido is on a distinguished road
Axis stuck
Hi TTL GS
Do you continue with the same problem?
I have just had the same problem and I solve it.
The problem starts with the axis X stuck, and sometimes the Dyna doesn't initialize.
The problem is the power supply, you have more consumption and the power supply fails. You can change the tolerance of the power supply Lamba LFS 48.
If you need more information, please contact.
  #11   Ban this user!
Old 12-18-2011, 08:51 AM
Wink X stuck HELPING
Hi JoseGarrido,
thank you very much for helping me.
I tried to find out how to chenge the tolerance but I've not been able to find the trim inside power supply. Can you kindly give me some more information?
Tank you and have a nice Christmas and a best wishes for 2012.
Giorgio Landi
  #12   Ban this user!
Old 12-18-2011, 09:29 AM
Power supply Lamda LFS
Hi TTS GL,
Tomorrow I will send the picture where you can change the ampere.
But its a potentiometer similar that the you uses to change the voltage 48-52V, that is sealed by white silicon in the middle of the power supply. You have to turn it clockwise, be carefull because its regulated to not burn the stepper boards, you have to make trials, you turn it a little bit and probe, until the machine will work fine. But if your problem is only when the dyna is running maybe in the first trial you solve the problem, in my case I have to do 3 trials because the machine sometimes doesn´t initialized.
By other hand, where did you find the Apu board?, because I had to buy it in Canada, I couldn´t find it in Europe. I bought it for this problem and also 2 stepper boards, and now I know that were fine.
Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos ckm Knee Vertical Mills 190 02-18-2012 12:42 AM
Just got a DM4400 maddog1927 Dyna Mechtronics 4 08-23-2010 08:27 PM
DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!! britcollector Want To Buy...Need help! 0 02-22-2010 09:20 PM
Mechatronics 3 Axis Stepper Motor Driver Chaka LinuxCNC (formerly EMC2) 8 02-10-2009 01:21 PM
Need Help!- Mechatronics 4axis stepper board ironaxe2008 DeskCNC Controller Board 1 01-01-2009 10:47 AM
