Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 03-06-2011, 09:56 AM
*Registered User*
mntn-biker is on a distinguished road
Info on a Dyna Myte 2200?
I cannot find any "real" info on this machine other than it sounds like the company went belly up.
Does anyone know the travels?
Does it use a standard collet?
What is the max. spindle speed?
Thanks!
Mike
Old 03-06-2011, 07:12 PM
Fastest1 is on a distinguished road
Company is not belly up. Dyna Mechtronics 408-452-1010 Ask for Roberto. services@dynamechtronics.com No real support for the machines, some parts but very few. I believe the 2200 is the same frame in general as my 2400. ER16 collet. My max spindle speed is 10000 on the pot, not sure if it will hit it. Spindle motors are on the light side. Btw the machines are highly accurate and were very well built. Capable of cutting any metal. I would guess your travels to be in the X 5", Y 4" & Z about 4 of travel but the spindle and the quill will allow quite a bit of room for set up.
Old 03-06-2011, 07:20 PM
Though this site probably has the most Dyna info I have found, the yahoo groups Dyna group is ok too. These machines do pop up on Ebay and various places pretty regularly. There are some great documentations here on the zone of at least 2 Dyna's of this size range that I can think of offhand.
http://www.cnczone.com/forums/bencht...t_-_build.html
http://www.cnczone.com/forums/knee_v...pdate_not.html
Those builds will have quite a bit of info and pictures for you. The builders did a good job on the conversions. Also did you get the software when you purchased your machine? The dongle? Most likely you didnt. If you did great, if you didnt just convert it over to a modern controller and save yourself a headache or 2.
Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos ckm Knee Vertical Mills 190 02-18-2012 12:42 AM
Dyna Myte touch probe info requested mfgbydesign Dyna Mechtronics 31 04-24-2011 11:06 AM
DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!! britcollector Want To Buy...Need help! 0 02-22-2010 09:20 PM
Dyna 2200/2400 Program to Computer basch3 Knee Vertical Mills 1 05-04-2007 08:41 PM
Dyna Conversion from 2200 to Mach New 2 CNC Benchtop Machines 0 12-04-2006 10:46 PM
