Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 11-14-2010, 09:14 AM
2ferrous's Avatar
2ferrous is on a distinguished road
A funny thing happened on the way home...
Its the end of the day and I'm homing the machine and the X axis faults out and triggers the alarm. I think, no big deal and reset the machine and re-home. Same thing happens.
Now I'm thinking that the limit switch is dirty and needs cleaning. So I remove the cover and use my finger to activate the switch and it works fine....? I reset the machine again and re-home. The switch doesn't even make it to the stop before the machine trips out.
I remove the rear table cover and its jammed full of aluminum chips. It appears that the chips got caught in the physical limit stops and faulted the X axis before the home switch could be triggered. That would explain my creeping home position too....
So for you DM4000/4400 owners out there. You might want to take a look under the rear covers once in awhile just to make sure everything is clear.
I'm going to design a better front and rear Y axis way cover to try to eliminate this problem.
Timothy
Old 12-07-2010, 04:27 PM
Brick58 is on a distinguished road
It happened to me on one of my 3000Hs. It wouldn't home, so I took off one of the covers. It had a bunch of chips there. Cleaned them out. Better, but still wouldn't home consistantly. I sprayed some penetrating oil on the plunger and cleaned with a q-tip. It removed some gunked oil. Then it homed OK.
Tom
Weird thing happened with my Viper 200 Danno Viper Servo drives 5 01-21-2010 02:47 AM
What happened to the home cast mill? ZipSnipe General Metal Working Machines 1 01-06-2008 07:48 PM
A funny thing happened on the way to the forum BIG AL General Metal Working Machines 2 01-29-2004 02:15 AM
Funny motomitch1 CNCzone Club House 8 01-27-2004 04:01 AM
