Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 09-21-2010, 03:00 PM
hmc710 is on a distinguished road
Delta 20 is Lost
Have a Clausing Mill with Delta 20 control. Programmed last week and ran just fine. I turn the power off when we are not using the machine. Powered up, ref axis and got Z limit travel fault. Cleared the fault and didn't think much of it. Wrote a program, set up a part, set up X zero and Y zero, hit Start and mach took off in x+ and y+ til y limit faulted. Powered control down and tried again, same result. Opened cover on z limit and had a broken wire but making contact. Fixed wire, still got z limit fault. Mach would zero on z ref but give a z+ limit fault. Checked z high limit travel set up and it was set to 0.0000. Changed it to .0100 and z limit fault went away. (Maybe machine was not completing the axis ref routine I surmized). Powered down and ref axis, no fault. Call up program with a x,y position and z axis takes off in z+ until limit faults. The x,y take off doesn't happen now, but now its z. When I ref mach all axis indicate true positon. I Home mach and all axis go to true position. I called up program I did last week and I get the same results, z+ takes off. I am guessing I have a ref issue. Any thoughts? The mach has lost its mind before and we just power it down. I did go through the cabinet and push on all connectors and boards.
Thanks,
H
Old 09-22-2010, 07:13 AM
trevj1 is on a distinguished road
Dynapath Delta 20?
Try the Dynapath forum. Probably get better hits and info there. http://www.cnczone.com/forums/dynapath/
Different outfit from Dyna Mechtronics.
Cheers
Trev
Old 09-22-2010, 07:32 AM
Thanks Trev, I knew I saw dynapath on here somewhere, maybe I need to get out more often!
H
Delta VFD -E help woodguy60 Phase Converters and VFD 1 03-19-2010 10:47 AM
Delta Tau cnc-it General CNC (Mill and Lathe) Control Software (NC) 3 04-29-2008 11:07 PM
delta 40 rhurt Tree 0 03-24-2007 10:33 PM
Wye-delta, delta-wye configurations? mackeym Phase Converters and VFD 10 09-27-2006 05:02 PM
delta tau Jeremiah Servo Motors and Drives 9 06-22-2006 07:41 PM
