Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Dyna Mechtronics
Dyna Mechtronics Discuss Dyna Mechtronics here.
Old 09-02-2010, 09:39 PM
maddog1927 is on a distinguished road
wild / high leg placement? on DM4400
I have a 10 hp rotary phase converter that puts out 110 / 110 / 220 each to ground.
Which terminal do I hook the 220 leg (high / wild) to?
It is an andersonconverters.com converter but it IS NOT their CNC converter.
Would the previous owner have smoked this machine using this converter? I saw it hooked to this converter but never saw it run.
Old 09-03-2010, 09:21 AM
dave design is on a distinguished road
I'm no expert on rpcs, though I did months of research trying to understand them ;+}
Unless this is some strange animal, you should have ~220V between _any_ 2 of the 3 hot legs, and 110-120V between any hot leg and neutral. I don't understand why one hot to ground is that high. Are you testing it unloaded, and are you sure you're actually measuring the hots?
Also, as I understand it, an RPC needs to be "tuned" to match the load to the converter, the goal being to get all 3 legs to be the same for a specific load condition. Unloaded, they can vary a bit, but surely not 100V! Regarding the size, I would think a 10hp converter would be enough to run a whole shop, so I don't think the converter is undersized for the Dyna.
DM4000 DM4400 manual 2ferrous Dyna Mechtronics 3 05-17-2011 12:20 PM
DM4000 / DM4400 DM 2400 manuals maddog1927 Dyna Mechtronics 6 10-26-2010 06:51 PM
Just got a DM4400 maddog1927 Dyna Mechtronics 4 08-23-2010 08:27 PM
Need Help!- Machine Gone Wild bill south Benchtop Machines 6 07-29-2009 01:25 PM
Problem- DM4400 problem with turnovers spindle gelos Knee Vertical Mills 2 10-24-2008 02:16 PM
