| Dyna Mechtronics Discuss Dyna Mechtronics here. |
I purchased a DM2800 originally equipped with a probe. I received the machine with a cable and no probe, evidently lost in shipment. I would like to add this functionality and looking for any knowledge, such as: a picture of the probe, how many wires (my cable has 2 wires that look like they were attached), Normally Closed or Normally Open, what is the sequence of operation when using the probe. Also looking for a suitable replacement. Thanks in advance. |
| Look under Zarzul here on the zone. He makes a nice probe. I believe it is now being sold under Wild Horse Innovations? Nice piece anyway. Try starting the probing routine on the 2800 and touching the 2 wires together if it stops it is right, if it never moves try initiating the probing sequence when the wires connected. The best way I believe is to have a normally open switch and if a wire breaks everything stops til you fix it. If it is normally closed it just keeps going. I too have a 2800 though I havent pulled it out of storage for a refit with Mach. Mine is complete less any way rs232 software or cards. On my Dyna lathe the limit switches were wired NC. I just had to change the setting in Mach. If I could find the exact replacement switches in NO, I would replace them but they do work well in all of my tests so far. |
| Damn I just reread your post. Was it shipped with the probe and it fell out? I lost some Dyna lathe tooling when a member packed something with no consideration for anything but my money. Lost a few pieces that are not in production nor do I see them on Ebay or elsewhere. Will solve those problems when I get there. Hope it helps. Are you on the Yahoo group? There is a little activity over there. |
Ok I realize this is the odball question of the month, but here goes. I've been working on a DM2016 (see thread in this forum), and was wondering if it would be possible to use my Renishaw touch probe. I've found the J34 connector on the main board, but I assume this expects a simple switch, i.e. either no or nc. If the switch opens again (or closes), does motion resume, or does it stay in feed hold. Also, does the switch making stop motion in all axes or only Z? I realize it's intended for a toolsetter probe, but I thought just maybe... Looking through the Renishaw verbiage, it doesn't look like it outputs anything like a simple low or high. It has something labeled "pulsed (skip)", which I believe is exactly what it says, a pulse of some duration that tells the control to stop right now, but it does not stay in that state. |
| Dave Design, It's my understanding from what I've read that the "touch probe" can be used in SETUP mode to pick up offsets (one axis at a time). To do this you lay the probe on the side between the tool and work and jog the machine into it. I recently aquired a probe (thanks 2ferrous) but have not had a chance to try it yet. Working an hour drive from home is seriously cutting into my Dyna time, but that's soon to change. I'll post some pinouts along with states (NO, NC) or some sort of description when I get a chance, but probably next weekend at the soonest. |
| I'd be interested to see if it works, at least manually. The auto probing option did cost extra, and sadly, isn't on my machine. From what I can see in the manual and from Roberto at Dyna, I would need an M42 macro program, which isn't there. M42 just gives me an error, and the M42 macro is physically not present in the 4M_SUB.DAT file. My interest wasn't so much toolsetting, but a spindle probe like this http://www.renishaw.com/en/mp700-hig...ch-probe--6104 but if the tool probe can tell an axis to stop, a spindle probe could do the same.
#10
This thing was beating me over the head with a 4X6 trying to tell me how to make it work and I was just ignoring it! The magic command to make probing in any axis work is the skip command, or M64. What I didn't understand is this command is modal, that is, it's active until canceled. So my little Z probing routine looks like this: M64 N-56 //modal command, wait for signal X-56 to go low ("probe touch", short pins 1 and 5 on J34 big control board)// G1 Z-1. F1. //start moving down in Z (but M64 is still waiting for that signal!)// M0 //when the condition specified is met in the M64, go here!// I kept trying to put the M64 after the move command, and of course, it just patiently waited until the move was complete and did nothing. There is a big problem remaining, however. I can get the axis to stop when the probe touches, but how do I capture the position and go to the next part of the macro without having to hit cycle start again? Oh wait, this just in. All I need to do is insert a move command in place of the M0. Obviously, I'd want to capture the position where the axis stopped before, I know that's somewhere in the macro commands, but apparently any move command cancels the previous one in progress and goes where you tell it. This would also work with a Renishaw toolsetter probe like the TS-27, as well as the original Dyna unit, and of course any spindle probe. |
#11
YouTube- ‪Renishaw probe on Dyna Mechtronics DM2016 mill‬‎For some reason, the Renishaw "pulsed skip" output or whatever they call it doesn't trip the probe trigger logic on the 4M control. Maybe the 40msec pulses are too fast for the control to notice. No matter, I switched to the probe status output of the Renishaw OMI (big round device to the right of the probe), and it's working fine now. That output stays low as long as the probe is tripped. If anyone needs help with spindle or toolsetter probe setups on a Dyna 4M, I'd be glad to help. I would post macros, but A, I haven't written them yet, and B, Renishaw may be unhappy about this because their probing cycles are copyrighted. |
| Dyna Mechtronics 4400 (DM4400, dyna myte) reference + brochures & photos | ckm | Knee Vertical Mills | 190 | 02-18-2012 12:42 AM |
| DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!! | britcollector | Want To Buy...Need help! | 0 | 02-22-2010 09:20 PM |
| looking for a Dyna Myte DM2400 | rcm | Want To Buy...Need help! | 3 | 05-15-2009 12:58 PM |
| Need Help!- DYNA MYTE PARTS | davidponte | Want To Buy...Need help! | 0 | 04-12-2008 07:28 PM |
| collets for dyna myte | GARG69 | Benchtop Machines | 2 | 05-20-2006 03:43 PM |
