- Help needed on programing a dynapath 50 controller
Is there any chance some one could post a very simple program that will mill a round hole on the inside of a circle using cutter compensation.
I have been reading a dynapath manual and posting the code exactly as it is typed in the manual for the better part of 2 days. The results I get are not the same as the pictures in the book.
I was using a .25 inch end mill and I have that loaded in the tool look up table.
You can pick any size you want but keep the numbers even. I am looking for the KISS principal here. I want to compare a program with cutter compensation using G3 and a .25 inch diameter bit.
Any help would be greatly appreciated. I am working with a dynapath 50 controller.
Will
Re: Help needed on programing a dynapath 50 controller
Never mind the previous question. After sleeping on it I started in again and realized that while a circle is a complete arc I should have been using the circle mill event and not an arc mill event. All is better now.
- You may not post replies
- You may not edit your posts
Forum Rules
