It is a custom line transformer then convert your LINE power (110VAC think) into 2 outputs: 115VAC need to supply spindle, magnetic contactor and brake, and 18VAC than summed with 115VAC=133VAC need to supply axis motors, and logic 5VDC(distrib board and controller), i think that an 8A 1050VA transformer can be sufficient, if you want can buy separated trasformer, one for 115VAC 1KVA and other for 18VAC 30VA, you must connect secondary coils in series
