Hi All,
What version of Windows will run the Dynacom.exe file?
Cheers
The 3000H is the larger of the two. The 3000 is the bench top model. The stand is part of the 3000H.
Looks like the 3000 weighs about 550 lbs whereas the 3000H is over 1000.
thanks for the reply, appreciated.
Cheers
Phil
Sorry, I got distracted from it after the holidays, and since then my partner in the machine and I decided to convert it after all. If you still need a bobcad post then I suggest going to bobcad for it, as far as the fusion post, I think it's pretty good but fusion doesn't have any way to use our canned cycles. It seems to be more for g70-g73 canned cycles but ours more resemble pure facing and turning cycles. I wanted to help out with the bobcad end of things but I'm just too involved in other things right now.
It's a msDOS executable. I know there are many pages and different topics from post processors to cables to serial ports but read through this thread. I was able to run the file in a DOS emulator called DOSbox complete with serial communication, I was able to write a messy qbasic program that is in my manual and compile that into exe and run on a modern PC in a cmd screen(don't recommend this, the program isn't well written) and I was also able to send the file with an open source free dnc program called edytornc. Predator editor should also be configurable for this. The 386/486 PC is what dynacom.exe is designed for and it would be an easy solution but there are several solutions in this thread that don't require you to buy another antiquated dusty machine. To send files to and from the Dyna machine.
Thanks danxj7x,
I'll try and get my head around what you have written and setup communication with the 3000.
I have it running with the original software and running very well, it would be better if I could use a screen instead of one line at a time.
Roberto has helped me a lot by answering my questions, and, like I said, it is now running very well, and holding sizes extremely well.
Regards
Phil
Would it be possible to get a copy of the program for the DM3000?
Regards
do you still need the program..if so i can help
Big Chipin, spreading tha cheese, I be Big Chipin for days!
I see this thread is getting pretty dated but if anyone can share a working link to dynacom.exe that would be great. The dropbox link earlier in this post is no longer working.
Hi please give me a copy od dynamyte.exe
Is it possible using it for dynamyte 2800?
Please can I get a copy as well I just got 2 dm2800 I spent a bit of money on and broke the laptop that came with them now I can’t run these mills at all I have no manuals for them either so I’m really stuck.
Is there a way I could get a copy please
i have tons of parts if anyone is interested
anyone have any interest in any dm2800 parts i have drivers board steppers and like 5 controllers i might even part with one of the cnc i have it needs repair that is completely out of my scope of knowledge,
Is the dynacom software available somewhere?
I am mostly interested in how to do a bulk dump on EM-3116, does the software offer the possibility?
