Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 01-11-2010, 04:49 PM
Danno is on a distinguished road
Tool offset not activating
I have Dolphin Cad, and I'm running Mach2 on a milling machine.
Everytime I make a part that requires a tool change, the tool offset for the second tool does not activate.
Just before the request for the 2nd tool to be put in (manually), there's a G49 command to cancel offsets.
When I hit start after the tool change, I've been told that there should be a G43 command to enable offsets. My PPR is not putting it in there.
Could someone please show me what line to modify in my PPR file to install a G43 command after a tool change !!
Thanks for any help.
Old 01-11-2010, 05:00 PM
dgoddard is on a distinguished road
How about sending me your Dolphin Partmaster Cad and Cam files and I will take a look at them.
Old 01-11-2010, 09:26 PM
No problem;
Where should I send them to?
I'll send a copy of the PPR file I'm using also.
Old 01-12-2010, 05:44 AM
After a bit of thinking, I don't think the issue is with the Cad or Cam files because there are no provisions for tool offset information.
I would still like to find out how to add a G43 code to my PPR after a tool change.
Anyone?
Need Help!- Offset, measure the first tool and second tool domax Daewoo/Doosan 14 12-29-2009 10:20 PM
Changing tool diameter in the tool offset screen Vern Smith Haas Mills 21 09-24-2008 09:54 AM
Activating the waylube pump ? Shizzlemah Fadal 6 08-27-2008 02:50 PM
Activating HPCC in a sub-routine? Dawson Daewoo/Doosan 0 03-18-2006 02:04 PM
servos not activating Chris81579 Machine Problems, Solutions , Wireless DNC, serial port 1 03-11-2006 02:09 PM
