Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 11-18-2009, 04:58 PM
converterk is on a distinguished road
longhand cycles in post
Is it possible in the Dolphin postprocessor to have it post drilling, boring and tapping longhand instead of using cycles such as g81 g84 g85 ect?
Old 11-18-2009, 11:34 PM
harley4ever is on a distinguished road
I dont see why not. Maybe Andre can give some input on this though?
Old 11-20-2009, 04:09 AM
andre-dolphin is on a distinguished road
Yes, it's possible and quite easy.
In CAM select Edit from the top menu, then choose Post-processor, the current post will open, if this isn't the one you want then use File > Open and select the required post.
When you have the correct post, scroll down to the section CYCLES, here you find the cycles that can be used, cycles can be be CANNED, CALL or EXPAND.
CANNED is used for drilling cycles such as G81, G83 etc
CALL is used for complex cycles such as G71 / G72 in turning
EXPAND is exactly that - expanded into individual movements.
To change a drill cycle simple replace the word CANNED with EXPAND.
Note the word MUST BE IN UPPERCASE.
Then use File > Save As and give this modified post a new name so that the original is not overwritten and available in it's original format.
Please note :- when modifiying a post-processor, the syntax and format is crucial - always keep the orginial post, don't overwrite them, we cannot be responsible for posts that customers have modified and introduced errors into.
Last thing, when you come to use the post it will create a .ppx file if required, if you see this message just OK it.
Hope this is clear
Andre
Old 11-20-2009, 09:16 AM
Thank you
Need Help!- canned cycles astro cnc G-Code Programing 3 02-17-2009 08:40 AM
different peck cycles? C5turbo Fanuc 9 11-06-2008 05:03 AM
Drilling cycles inflateable EdgeCam 4 04-30-2008 02:42 AM
canned cycles on 16t? DocHod Fanuc 3 07-08-2007 07:58 PM
G90/G91 in canned cycles alfalfa CamSoft Products 18 02-25-2007 05:20 AM
