Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 11-11-2009, 01:51 AM
turbothis's Avatar
turbothis is on a distinguished road
thread milling
can i use a 60 degree double angle cutter to mill threads on mach 3 using the partmaster pro?
if so how do i go about doing this?
thanks
Old 11-11-2009, 04:29 AM
davereagan is on a distinguished road
Should be no problem. I don't know about your cam system, but you can just use normal G code as well. Your radius will be your major diameter minus the cutter diameter divided by 2. G3 is a helical interpolation if you give a Z coordinate and a lead value as well.
Old 11-11-2009, 11:16 AM
andre-dolphin is on a distinguished road
PartMaster Pro (Level 3 in the UK) has a threadmilling function.
Define a Pattern in Cad as though you were going to drill it, then in Cam use the Threadmill item from the main operations toolbar.
Using the standard mach3 post "m_mach3" will output consectutive G02/3 moves with a corresponding move in Z.
I will upload an example program and drawing.
Hope this helps
ATB
Andre
Old 11-11-2009, 11:24 AM
Here is the file.
File Type: zip Thread Milling.zip‎ (1,003 Bytes, 67 views)
Old 11-11-2009, 03:48 PM
harley4ever is on a distinguished road
Thats what I was going to say. Use the threadmilling option in the cam.
Old 11-11-2009, 10:58 PM
turbothis's Avatar
yes, i played with it some this morning and got it about figured out.
now to start on either the rotary or z profiling next?
Need Help!- Thread Milling Doubleddaved Haas Mills 4 09-12-2009 09:05 AM
Newbie- Thread milling shake n bake Mazak, Mitsubishi, Mazatrol 2 01-09-2009 04:04 AM
thread milling help BAD DOG Daewoo/Doosan 1 11-28-2008 12:20 AM
0M-Thread milling? mikul Fanuc 1 12-05-2006 11:56 PM
thread milling STS_Kevin Daewoo/Doosan 0 11-28-2006 06:50 PM
