Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 07-26-2009, 09:07 PM
japcas is on a distinguished road
Contours vs. Profiles?
Hey guys. I've been using Dolphin cad cam to program my mill. I usually draw up my parts in another cad program, import them into dolphin cad to create the needed contours and patterns, and then move to the cam side to write the program. I've been using the contour function all of the time. What is the profile function used for? Is it used for lathe functions or am I missing something?
Old 07-26-2009, 09:39 PM
2Bits is on a distinguished road
Good question, I came to the same conclusion you did.
Old 07-27-2009, 03:30 AM
John S. is on a distinguished road
Very simply contour is a horizontal surface, profile is a vertical surface.
Say you want to machine a fancy base for a trophy with a curved side or ovolo shape, you would draw the base shape as a contour and the side as a separate shape, like a sectional line as save that as a profile
Then when processing you tell it to use the contour but follow the profile in Z
There are some worked examples in the examples / tutorial folder [ not at my machine at the moment ] that when run give you an example of how to use the two.
John S.
Old 07-27-2009, 07:40 AM
Thanks for the great replies. That sounds simple enough and easy to understand. My machine is only a 2 axis machine, I move the z axis manually. One of these days I'll build a 3 axis machine.
Error at synchronisation of contours qwerty1000 Mastercam 4 09-18-2009 10:27 AM
Text Contours (Ellipse) TZ250 Dolphin CADCAM 4 05-10-2008 12:22 AM
Question on creating Contours in CAD mrcodewiz Dolphin CADCAM 25 04-20-2008 02:22 PM
Remove contours of a shape chips_ruiz Visual Basic 0 02-06-2008 12:06 PM
CAD/CAM for Instrument Contours????? NardisAmps Musical Instrument Design & Construction 8 01-30-2007 07:33 PM
