| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
I've been able to get up to speed with importing dxf's into partmaster cad, creating an origin, contours and hole patterns then passing to cam to create toolpaths. i'm trying to figure out a way to update the cam contours without starting an entirely new cam file. i.e. i have imported contours and a hole pattern into cam then 3/4 of the way through creating tool paths i realize i need to edit a contour, or add one, or change/add a hole pattern. is there some way to update the geometry in cam without starting over? the 2 things i've tried are using the cam geometry editor and cut/pasting operations. the cam geometry editor is the most painful program i have ever used. cutting and pasting operations form the old cam file to the new one is flakey, sometimes it works, sometimes the operation will reset back to defaults like depth of cut, approach, etc. also, one level up. i create everything in solidworks, then output a dxf. is there a way to import a new version/udpate a dxf into partmaster cad without creating all new contours, hole patterns, etc? thanks Mike |
| Oops ! I suppose I should tell you where the movie is - senior moment. www.dolphin-online.net Goto the miscellaneous page. ATB Andre |
| Thanks Andre. That really helped me out and I'm sure it did others as well. It seems it never fails that I would get almost through on the cam side and realise I left out something important. I usually just started over but this should really save some time. Thanks again. |
| geometry | ticko2 | Mechanical Calculations/Engineering Design | 3 | 04-22-2009 05:15 PM |
| geometry | Htech | Fanuc | 1 | 12-09-2007 11:25 AM |
| Geometry from NC | rherman | BobCad-Cam | 2 | 09-21-2006 07:10 AM |
| passing arguments to a sub program | kiprip | Mazak, Mitsubishi, Mazatrol | 1 | 07-13-2006 11:11 AM |
| Can v9 save geometry as a .dxf or .dwg? | badRandle | Mastercam | 2 | 06-03-2003 01:33 PM |
