Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 07-13-2009, 10:04 PM
rogerfries is on a distinguished road
Importing .BMP or .JPG into Dolphin CAD
I want to import a shape that I scanned into a .BMP format into Dolphin CAD, but when I select File/Import/Bitmap I browse to my file a select it, but nothing seems to happen. What's the best way to get a .BMP or .JPG type graphic into Dolphin.
Any Ideas?
Thanks!
Old 07-14-2009, 06:42 PM
harley4ever is on a distinguished road
There is something in the whats new section that explains this I think.
Old 07-15-2009, 07:09 AM
sqatch is on a distinguished road
Select import choose your image then click the image icon on your tool bar (the green cactus) which will bring the image to the work area then click to drop it. You can also set the scale in the properties dialog box.
Old 07-15-2009, 12:57 PM
Thanks,
I found the cactus and was able to drop the image on my drawing. I could not seem to size it however. I change the values in the dialog box and nothing happens. After It's in the drawing, it has handles. I try to size it with the handles, but as soon as I release the mouse button it just goes back to the size it came in at.
The next problem, How do I trace it to generate tool paths?
I did have some success with a program I found calld Magic Tracer
http://www.magictracer.com
This converts it to a .DXF file. It has a free to try, but $60 to buy. This works pretty well, but it would be nice to do the whole process in Dolphin if I can.
Old 07-15-2009, 10:37 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.inkscape.org/ inkscape is free and is in my opinion the best option out there for creating vectors from raster images , you can save as dxf and then import into Dolphin . after that you can scale the vector to whatever size you would like in dolphin
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 07-16-2009, 06:58 AM
In Dolphin I trace manualy, that way I get the lines I want without a bunch of dead ends to clean up.
Old 07-16-2009, 10:03 AM
Sqatch,
How to you trace in Dolphin? I'm very new to Dolphin.
I'll also give Inkscape a look
Thanks both!
Old 07-16-2009, 09:52 PM
Use the curve tool and draw lines over the bmp. Use a different layers and colors for more intricate drawings. You can also go back and move near points with the move point tool. In the view menu select near points.
Need help importing dxf to DCAD 2Bits Dolphin CADCAM 10 03-02-2009 01:16 AM
Dolphin Demo / Dolphin Sales / Dolphin Support Dolphin USA Dolphin CADCAM 0 02-07-2008 12:19 PM
Importing dwg.files wsteve Rhino 3D 2 05-09-2007 02:51 AM
Importing Images .bmp, .jpg chase78 Mastercam 13 05-08-2007 09:18 AM
importing .dxf ToddAnderson OneCNC 9 11-11-2006 12:34 PM
