| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
So I know how to use Rhino well so I prefer to draw in that, but when I try to import into Dolphin CAM it doesn't show some of the curves I've drawn. It shows lines and circles that have been cut, but not line made by free form in Rhino. Can anyone help with the importing or exporting from Rhino or how I should draw it in Rhino so I can get it to import correctly into CAM for lathe work? Thanks. |
| Hi there, Were the curves arcs or polylines/splines? Just had that same problem myself, Dolphin doesn't seem to like curves that aren't plain ol' arcs... Regards, Jason Ok, sorry - I see the 'free form curves' part now! I'd suggest that might be the problem? Last edited by Jason3; 05-02-2009 at 04:49 AM. Reason: Should have read OP's post more carefully! |
| Change your export options to export as arcs/polylines, and try saving as v12.
| I don't have rhino installed here, but I have used it in the past, and there are a ton of .dxf export options. Sorry, but I can't direct you to them.
| I still didn't find an option box or anything in Rhino for DXF or export settings, it's probably lines you have to type in the command window. Doesn't matter I found some stuff on how to do it. One way was to click on the curve and click convert to arcs. That worked. Thanks for the help. |
| Engraving in Dcam help | L2A3 | Dolphin CADCAM | 9 | 06-29-2011 01:37 PM |
| Rhino Video Tutorial - Create a Diamond Solid in Rhino | Robert Schutz | Rhino 3D | 2 | 06-02-2008 01:58 PM |
| Rhino meshfrompoints vs. Point Cloud for Rhino | kaz | Rhino 3D | 0 | 11-13-2006 01:55 AM |
| The Rhino Pen: A Gallery of Rhino Drawings | BobWarfield | Rhino 3D | 4 | 06-08-2006 11:19 AM |
| Has anyone used a Rhino Controller (Not Rhino CAD) | runnoahrun | General Electronics Discussion | 0 | 10-31-2005 04:42 PM |
