Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 04-28-2009, 07:47 PM
Jason3's Avatar
Jason3 is on a distinguished road
Question Dolphin Partmaster Lathe Mach3 Post problem?
Hi all,
Hopefully someone can help me out:
Trying to post code for a simple part, I get an error message on opening the code in Mach3: "Radius to end of arc differs from radius to start line 31". I've tried changing the IJ mode to incremental, but that doesn't help. I've tried redrawing the original .dxf, and tried both the Mach3 post processors, and now I'm lost.
The strange thing is the first time I used the software (this was the second time ever), it worked just fine. Same lathe, same Mach3 settings, no problem. Dolphin support suggest I need a custom post, but I don't understand why - there's nothing special about my Mach3 setup, and it worked fine first time.
Any help would be gratefully received!
Best regards,
Jason
Old 04-30-2009, 02:41 PM
Smitty911 is on a distinguished road
With my limited knowledge of Dolphin. If you zoom on the area you will see that those points are not connected and that will need to be fixed. The CAM never fixes mine when that happens.
Old 04-30-2009, 04:57 PM
Jason3's Avatar
Thumbs up Thank you!
Smitty, thank you for the suggestion - that may well be it. I will check the drawing more carefully and see what I can find, I'll let you know how I get on.
Many thanks,
Jason
Is Dolphin Partmaster Pro good? bkboggy Dolphin CADCAM 22 03-22-2012 03:19 AM
Need Help!- Dolphin partmaster mach 3 post processor Goesman Screen Layouts, Post Processors & Misc 3 02-06-2009 03:15 PM
Car club plaque relief done with Dolphin PartMaster metalworkz Dolphin CADCAM 4 09-17-2008 09:49 PM
Dolphin Partmaster Level 3 rodneydeeeee Dolphin CADCAM 0 12-01-2006 02:24 PM
Dolphin Partmaster help for newbie? bdillard General CNC (Mill and Lathe) Control Software (NC) 3 01-07-2006 07:36 AM
