Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 04-08-2009, 03:19 PM
Gold Member
mlaws1172 is on a distinguished road
DFX problem
I installed the cam program and got registered but it wont let me import any DFX files. It says cad is not installed (it is) or I may have to re-install the program.
If I re-install do I have to re-register? Is this a problem?
Mike Laws
Old 04-08-2009, 06:56 PM
dblox is on a distinguished road
CAD not installed error
Hi, I have a similar problem when selecting the CAD files (or DXF's) when importing them into the CAM module also.
However, if I click the "CAD not installed or has never been run" error message away twice, I am able to simply click "open" and the file imports correctly.
There is also no thumbnail preview.
Are you referring to the Dolphin CAD files being imported and not a raw DXF?
You should not have any problem importing DXF's into the CAD module (I dont, anyway).
The error message, although probably a common bug, shouldnt prevent you from actually opening the files in the CAM module.
This error happens on two of my PC's, one of which is the licenced version, the other the demo.
I've learned to ignore it.
Old 04-08-2009, 10:38 PM
metalworkz's Avatar
metalworkz is on a distinguished road
You may have better luck importing the .dxf in Dolphin CAD and then you can prepare vectors etc. and send it to the CAM program for toolpaths. I tried and got the same error that you reported and both programs are installed on my system also. I mentions something about not being able to find the file so I moved it into the partmaster/drawings folder thinking that would fix it but it still gets the error. It opens the .dxf fine in the CAD side and it can then be sent to the CAM side.
Regards,
Wes
Old 04-09-2009, 10:30 AM
Gold Member
The two click trick works.
Mike
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
