Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 01-05-2009, 11:58 AM
sqatch is on a distinguished road
Z Profile
Does anyone know how to stop X move before Z move when cutting Z profiles in goround? This is causing a groove to be cut at the start/stop point. I can edit the post but it is a lot of work.
Old 01-06-2009, 12:26 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Do you think it can be compensated for at the CAD stage?
Regards,
Regards,
Wes
Old 01-06-2009, 10:39 AM
I have played around with drawing the profiles in different directions. No matter which way I draw the profile it still moves X first then Z. I think I have gone through all of the parameter settings no answers there either. Editing the post was not such an ordeal, only 28 lines and the product turned out perfect. Still I cant help thinking I am missing something simple.
Old 01-06-2009, 03:10 PM
John S. is on a distinguished road
Can you post a file ?
John s.
Old 01-07-2009, 12:23 AM
Here's the files ( dra. cnc. & txt. post )
Old 01-07-2009, 03:40 PM
Squatch,
have a look at this file.
I have used all your profiles and contours but on the goround command I have used approach and depart moves of 0.1" these also allow you to specify Z moves before or after .
I have renamed it to profile cut3 so it doesn't overwrite.
Old 01-07-2009, 11:31 PM
Thanks for that info the post came out fine with Z then X. Your the best.
Newbie- 3D profile in NC. scrapper400 G-Code Programing 0 12-02-2008 08:27 AM
X4 Profile old54pop Syil Products 28 10-06-2008 09:28 AM
Y Profile in Z skipper_52 Wood Lathes / Mills 3 05-16-2008 02:52 PM
Problem- Profile mrdipen SolidCam 3 03-16-2008 08:47 AM
Help with profile TPPJR OneCNC 30 12-27-2005 11:22 PM
