Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 11-08-2008, 11:52 AM
dave6 is on a distinguished road
The post processor mod. shows more posts than the CAM mod. ,how do I access and use the posts in the PP mod?
Exotic Welder
Old 11-08-2008, 05:47 PM
harley4ever is on a distinguished road
In the post processor compiler it shows posts for mill lathe and wire edm. If you dont have all the modules, thats probably why they wont appear. M_= Mill Posts T_=Turn Posts and W_=Wire edm posts
Old 11-08-2008, 06:08 PM
Thanks, I see whats going on. Can I use a Meldas mill post for a Meldas lathe and just rename the file T_ instead of M_ so the CAM will see it? Whats the difference between the posts? There is a Meldas mill post but no Meldas lathe post that I can see.
Exotic Welder
Old 11-08-2008, 06:24 PM
John S. is on a distinguished road
No, Mill and lathe posts are very different.
Mill uses X and Y for the table and Z for the head.
Lathe uses X for cross slide and Z for bed movement.
Try using a generic lathe post and see what it spits out and then post what's different / needed for the Meldas.
Try the T_F6 or T_FOT posts for the fanuc lathe
Comparing a known post to a good part pst is about the only way you can get a post to suit your machine.
John S.
Old 11-08-2008, 06:32 PM
OK thanks...that makes sense that they would be different. I think Mitsubishi Meldas controls are very standard so as you said the Fanuc post may work well. I will give your suggestions a try.
Exotic Welder
Edit Tool Change Macro Oi-MC dtmtim Fanuc 4 09-21-2007 07:34 AM
Edit Post to use Tool Size Offsets on Controller lorindan Post Processor Files 0 08-11-2007 02:24 PM
EDIT O9000 tool change macro fanuc 0M mikul Fanuc 1 04-20-2007 06:06 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
Edit Options 18T Again pinguS Fanuc 2 08-02-2006 01:11 PM
