| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
I have level 3 of the software and am attempting to engrave text on a radius. I am trying to engrave text lengthwise along a 1.5" diameter tube. I thought I should be able to create the text (with nc contours) and then do a goround on the text applying a Z-Profile that I created. I am using a simple font and without the Z everything seems OK but once I apply the z-profile, it just goes to heck. It seems to be cutting the depth of the profile (which is basically a section of a 1.5" diameter circle) but I only want it to cut .005 deep. Could anyone tell me how to do this? Edited to also ask - what is a good cutter to use to do this? The engraving will be about 1/16 high and .005 deep and I am using a mini mill. |
| The software I use, has me create a solid or surface. Then the text has to be vectorized and projected on to that surface. From there it's just a matter of homing the machine to the part and off it goes.
__________________ "Plan your work; Work your plan" |
| Did you check the depths: 1) of the tool being used as defined in the tool definitions 2) the depth of the engraving dialogue box 3)and I believe there is a depth overide option in the Z-profile settings? Regards,
__________________ Regards, Wes |
| Yeah, i think the problem is with how I am applying the Z profile. I am trying to just create a slice of the tube as the Z but it looks like what I may actually have to do is create a Z profile that is exactly as tall as the letters which means I need to figure out exactly where the lettering will be on the tube? Maybe I am just overcomplicating this. |
| There is a good detailed help file with various options for the Z-Profile machining in the Help files. Just search for Z-profile. It should not be too hard to figure a ballpark size of the engraved area and implement it into the definition of the Z-profile to see if that will fix the toolpaths. Regards
| Johns question about the rotary axis gave me another idea for a work around. Even without a rotary axis one could set up the part on centers and do the engraving one line at a time providing it is to be done in lines of text and not a single big logo etc. Engrave a line of text and then rotate the part for the next line and lock the centers. The engraving locations could be layed out on the part or you could use a pointer and index each line. A step backwards perhaps but might serve as a work around in a pinch. Regards,
#10
| Well, I decided to just do it a single line at a time. I chucked it up in a collet indexer and did it line by line using the Mach3 engraving wizard. Not ideal but it worked OK and was probably quicker than fighting with the z-profiles. |
#11
| I know you probably wanted to utilize the software but I'm glad you were able to get it done with the work around. I'm glad I have several small manual machines in my shop to use for simple stuff or 'work arounds' and second operations and have really been utilizing them a lot lately. I have not done any work using the Partmaster Z-profile option yet but want to start using it so I can become more familiar with it. Regards,
| Problem- radius help | Scott Halstead | GibbsCAM | 0 | 06-12-2008 07:27 AM |
| big radius | Dembo | Mechanical Calculations/Engineering Design | 10 | 02-01-2008 11:01 AM |
| Help with radius in mazatrol | rstephen | Mazak, Mitsubishi, Mazatrol | 24 | 04-05-2007 07:30 AM |
| Radius in z axis? | pp-TG | G-Code Programing | 4 | 01-24-2007 05:18 PM |
| Zero Radius Arc | Xular | Mach Mill | 4 | 12-13-2006 09:10 PM |
