| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
Hi everyone, So I can finally draw my parts in DFX file format. I can import them into DCAD and I can create the machining contours (I am just making a series of 0.14 inch holes in a rectangular piece of aluminum.... I am building a tooling plate). I run the machining simulation in DCAD and it looks good. That is to say, the simulation does what I want my mill to do. Next, I go to "post process" to create my g-code. I am using Mach3 to run my little Taig mill so I chose "LM1-MACH3.ppr" and I left the "file extension" as "pun". Following that, I load that g-code file into Mach3. This is where the problem is: Mach3 can not read the g-code. Mach3 says:"Unknown word Starting with rline1". So, how do I generate G-code that Mach3 can understand? Thanks-Josh |
Here is the g-code or should I say N-code that DCAD generated.-Josh % ( Produced :- 14:42:24 Friday, May 16, 2008 ) ( CNC File :- V1 ) ( Post Processor :- L1M_MACH3 ) ( Part Number ID :- ) N6G00G20G17G90G40G49G80 N7G49 N8T1M06 ( End Mill ) N9G00G43Z5.0H1 N10S1000M03 N11X0.0Y0.0 N12X12.0Y5.5 N13X12.0Y5.5Z0.1 N14G01X12.0Y5.5Z-0.5 N15G03X11.9913Y5.5088I11.9913J5.5 N16X11.9825Y5.5I11.9913J5.5 N17X12.0Y5.4825I12.0J5.5 N18X12.0175Y5.5I12.0J5.5 N19X12.0Y5.5175I12.0J5.5 N20X11.9825Y5.5I12.0J5.5 N21X11.9913Y5.4913I11.9913J5.5 N22X12.0Y5.5I11.9913J5.5 N23G01X12.0Y5.5Z0.1 N24G00X12.0Y5.5Z5.0 N25S1000 N26X12.0Y6.25 N27X12.0Y6.25Z0.1 N28G01X12.0Y6.25Z-0.5 N29G03X11.9913Y6.2588I11.9913J6.25 N30X11.9825Y6.25I11.9913J6.25 N31X12.0Y6.2325I12.0J6.25 N32X12.0175Y6.25I12.0J6.25 N33X12.0Y6.2675I12.0J6.25 N34X11.9825Y6.25I12.0J6.25 N35X11.9913Y6.2413I11.9913J6.25 N36X12.0Y6.25I11.9913J6.25 N37G01X12.0Y6.25Z0.1 N38G00X12.0Y6.25Z5.0 N39S1000 N40X12.0Y7.0 N41X12.0Y7.0Z0.1 N42G01X12.0Y7.0Z-0.5 N43G03X11.9913Y7.0088I11.9913J7.0 N44X11.9825Y7.0I11.9913J7.0 N45X12.0Y6.9825I12.0J7.0 N46X12.0175Y7.0I12.0J7.0 N47X12.0Y7.0175I12.0J7.0 N48X11.9825Y7.0I12.0J7.0 N49X11.9913Y6.9913I11.9913J7.0 N50X12.0Y7.0I11.9913J7.0 N51G01X12.0Y7.0Z0.1 N52G00X12.0Y7.0Z5.0 N53S1000 N54X12.0Y7.75 N55X12.0Y7.75Z0.1 N56G01X12.0Y7.75Z-0.5 N57G03X11.9913Y7.7588I11.9913J7.75 N58X11.9825Y7.75I11.9913J7.75 N59X12.0Y7.7325I12.0J7.75 N60X12.0175Y7.75I12.0J7.75 N61X12.0Y7.7675I12.0J7.75 N62X11.9825Y7.75I12.0J7.75 N63X11.9913Y7.7413I11.9913J7.75 N64X12.0Y7.75I11.9913J7.75 N65G01X12.0Y7.75Z0.1 N66G00X12.0Y7.75Z5.0 N67S1000 N68X12.0Y8.5 N69X12.0Y8.5Z0.1 N70G01X12.0Y8.5Z-0.5 N71G03X11.9913Y8.5088I11.9913J8.5 N72X11.9825Y8.5I11.9913J8.5 N73X12.0Y8.4825I12.0J8.5 N74X12.0175Y8.5I12.0J8.5 N75X12.0Y8.5175I12.0J8.5 N76X11.9825Y8.5I12.0J8.5 N77X11.9913Y8.4913I11.9913J8.5 N78X12.0Y8.5I11.9913J8.5 N79G01X12.0Y8.5Z0.1 N80G00X12.0Y8.5Z5.0 N81M09 N82M30 % |
| Just out of curiousity... is there a reason that you are using the Level 1 Mach post? Are you doing everything inside Partmaster CAD, i.e. not using Partmaster CAM at all?
__________________ Dolphin CAD/CAM Support Download a free trial at http://www.dolphincadcamusa.com |
I get a weird result. The post processor simulation that runs in Partmaster Cam looks perfect. The end mill does exactly what it is supposed to do.... it makes 0.16 inch holes that are 0.5 inches in depth. However, when I load the g-code into Mach3, the code that is loaded does not reflect what was simulated in Partmaster Cam. Does anyone know what I am doing wrong. I attached the .cnc and the .pun file that I made in Partmaster. Thanks. |
#12
| Yes it was happy for me to see my K2CNC working the first time too. When I first loaded my G-code into the MACH3 software with the setting reversed my part looked like the many rings of Saturn in the plot window. |
| converting biesse code | sidskilly | CNC Machining Centers | 1 | 05-19-2008 01:43 PM |
| Converting a inch g code program to metric | joseavina76 | G-Code Programing | 3 | 12-19-2007 09:26 PM |
| Problem converting image to DXF. | MagooT | General CAM Discussion | 6 | 12-14-2007 01:37 PM |
| have converting problem | afri | Mastercam | 12 | 05-21-2007 07:37 AM |
| need help with converting corel to g code | pfcary1 | Commercial CNC Wood Routers | 3 | 01-07-2007 07:09 AM |
