Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 05-03-2008, 01:28 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Suggestions on milling large hole
Hi guys,
I have a 2" cube I need to machine a 1.125" dia. hole thru and was wondering what would be the best way to trap the slug to avoid binding on the tool as it cuts free. I plan on just milling a slot around the perimeter to cut down the machining time and thought maybe I can pin or trap the center slug so it won't come lose and bind on the tool? Any suggestions on a good way to do this? I figured I would just drill a hole in the center and pin the block to trap the center slug. Thanks for any advice.
Regards,
Regards,
Wes
Old 05-03-2008, 02:45 AM
VWSatOz is on a distinguished road
It wont bind on the tool anyway, the lump will just sit there! The problem will be if you try to use a small cutter say 1/4" diam that the cutter will be too long & flimsy to go through 2" thick (if milling steel), you would have to flip the block & come from both sides
Its best just to use a 16mm cutter with short flute length & slightly necked down shank so it can't rub (if on a real mill that can handle a 16mm cutter)
Old 05-03-2008, 09:02 AM
cam1 is on a distinguished road
Hmmm, drill first with the biggest drill you have.....then mill.
regards
Can't Fix Stupid
Old 05-03-2008, 09:34 AM
kbarratt's Avatar
kbarratt is on a distinguished road
Milling a large hole.
I would suggest corkscrew milling. This is great for blind holes as well. Use a good Indexable Insert end mill, with the ability to ramp down, as it does circular interpolation, like a cork screw spiral. No slugs to worry about, no starting hole needed, and it works great with blind holes as well.
I use a cutter that's not more than 7/8 of the finish hole size to allow for chip vacating.
3/4" Iscar Helimill, or Multimaster wold work well, providing it has the capacity for the depth you need.
http://www.iscar.com/Ecat/item.asp/a...100402/lang/EN
Old 05-03-2008, 11:46 PM
metalworkz's Avatar
Thanks for the suggestions and advice! I will probably try a variation of the methods offered here.
Regards,
Regards,
Wes
Npt thread milling pre hole sizes magneto259 General Metalwork Discussion 2 04-12-2007 06:33 AM
400x330x12mm AL hole milling fantasy2 Employment Opportunity 0 05-06-2006 10:54 AM
Milling Smooth Bottomed Hole? Otokoyama Benchtop Machines 3 09-12-2005 12:26 AM
G12/G13 hole milling JFettig Mach Software (ArtSoft software) 14 03-10-2005 08:23 PM
Milling a hole igorko General CAM Discussion 25 01-30-2004 05:55 AM
