| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
I know this should be easy, but I cant figure out how to do simple ramps on contours. For example, say I have a 1" X 3" rectangular contour that I want a 45 degree angle on from z Z-level of 0 on one of the long sides to a z-level of -1" on the other long side (all the way across). The examples I looked at on the dolphin site used 'GoRounds' to create z-profile contours around the outside of the part but that's not really what i want to do. It seems like what I really want to do is an area clear to a certain depth specifying a profile on that but I dont think that is an option. I am attaching a .dra file (renamed to .txt) if someone could help me figure this out. Thanks! Kevin |
| Alright - maybe I got this figured out. Instead of doing a contour of the entire part (the rectangle), I made a contour out of just one long end line and then did a goround with a right offset and it looks like maybe that is what I am trying to do. |
| You need to use the Ramp option under the Approach tab of the Goround dialogue. The attached file shows the principle (rename the .txt to .cnc), this file will probably only work with Vs10. There are lots of options for this assuming you have level 3. ATB Andre |
| I think that would work if I did it only along one edge but the example looks like it sort of ramps it but only around the edge - is it possible to use ramping on an area clea? I do have level 3 so whatever is available in there - Here is a rough sketch of sort of what I am trying to do. |
| I think if you draw the part and also draw the end view of the angled plane so it will be a single line the length of the inclined plane and at the angle of that plane you can use this to create the toolpaths for this feature. After sending it to the CAM side you can select the tool(Ball mill??) and then select create Zprofile from the machining drop down menu. For the Profile click the ? and slect the angled plane profile or select the profile from the dropdown list and fill in the needed blanks in the dialogue(X and Y start points etc).Click the Surface tab click Create Ruled surface, fill in the rest(Linear distance of slots, number of slots, machine alternate slots in reverse direction) I think that will do the inclined surface, and then you just need to do the remaining contours etc. Try drawing a simple example(that's what I did to see) or use the actual part if already drawn and view the simulation to make sure it looks right. I will attach the one I used for example. Not sure if this is the right way as I have not used this yet, but the simulation seems correct except it is not starting at the upper most corner and is milling more along the sides or the end mill, can probably start diferently to do it otherwise. Hope it helps. Regards,
__________________ Regards, Wes |
| I see what you mean now, Wes is right - use Z profile, as per his example. Just one more thing, if you wish to step down the cuts in Z use the "More Options" tab under Z profile and set the Cut depth accordingly, this will produce a number of Z passes but will not "fresh air cut". ATB Andre |
#12
| Mike |
| Rail profiles? | sp1nm0nkey | Linear and Rotary Motion | 3 | 02-04-2008 12:11 PM |
| Making your own custom endmill profiles? | saturnnights | General Metalwork Discussion | 5 | 05-02-2006 08:28 PM |
| plasma profiles | trevorhinze | CNC Plasma and Waterjet Machines | 12 | 01-24-2006 11:14 AM |
| Profiles for CNC lathe | Don C | Mini Lathe | 5 | 04-24-2005 07:17 PM |
| mkautomation - wooden t-slotted profiles?!? | Losos | 80/20, TSLOTS and other Aluminum Framing Systems | 5 | 02-06-2005 02:48 PM |
