Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 04-22-2008, 09:25 PM
BrassBuilder is on a distinguished road
Ramping into work
I have DolphinCad Level 2 and I see it supports the ramping feature on the Z axis. Where do I set this up?
Let me make sure I am understanding this term too. Ramping is when the bit eases into the work in lieu of plunging straight down, correct?
Mike
Old 04-22-2008, 10:59 PM
sqatch is on a distinguished road
ramping
found in the goround function you can set angle and distance.I would love it if it would ramp up for engraving, I spit my contours and ramp down from either end for that effect, its alot of work
Old 04-23-2008, 06:05 AM
OK. I see it now. I should be able to figure it out from here now.
Thanks!
Mike
Old 04-23-2008, 08:04 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Ramping makes a big difference, and I did not realize it until I tried it. So much smoother cutting and the start and end of the contours is not so noticeable.
Regards,
Wes
Old 04-23-2008, 09:30 PM
I need to give this a try soon. I cut some parts tonite, but I just used the drop straight down method yet.
Mike
ramping on a arc binzer GibbsCAM 7 06-10-2008 08:38 PM
Ramping Into A Profile partsman DIY-CNC Router Table Machines 8 01-15-2008 05:30 PM
Need Advice For Ramping Angle lerman General Metalwork Discussion 0 03-27-2005 12:49 PM
Ramping pauls BobCad-Cam 1 03-04-2005 03:49 PM
Ramping example? inthedark G-Code Programing 5 04-10-2004 08:53 AM
