| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
After having some really good experiences with DolphinCad, I had to redraw one of my parts and now the cutting bit takes the "scenic tour" around the part. I have three areas where it wants to do odd stuff. On Con_0 at each bottom corner, the bit wants to come up to .125 and then come back down into the work. On Con_1, it wants to go from the bottom right corner, do a really fast move over to the bottom left corner and then go back to the bottom right corner and pick up the cut again. Any ideas why it is doing this? I've attached a dxf of the part. Mike |
| I'll post back if my fix does not work. Thanks Mike |
| Hi Mike, I find its a good idea to zoom in and check things out closely before moving to the CAM side. It will help eliminate un-joined contours and lines that go past the intersection etc. and unwanted tool movements. Sometimes during re-examination you may even see a better strategy for the toolpaths. Regards,
__________________ Regards, Wes |
Thanks Mike |
| Finally got my part milled tonite. Need to do two more yet. Wow. The last two weeks sure have been a real learning experience in drawing and running the mill. Now that I am learning my way around DolphinCad, I am not sure I will be able to go back to TurboCad. In fact, I have TC Pro 12 with the CAM plug-in laying on my desk. I got it loaded and messed around with it a little, but the ease of getting around Dolphin is giving me second thoughts on moving back to the TC software. And now...a local shop wants me to start learning SolidWorks to do some part drawings for them. Going to start on some parts that are a little more complicated. This ought to present a challenge. Thanks for all the advice so far! Mike |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| BattleAxe "aka" Ball and Chain "aka" the wife. | ZipSnipe | CNCzone Club House | 48 | 05-18-2008 09:53 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 04:00 PM |
| Cutting "out" items from a sheet | MrBean | DIY-CNC Router Table Machines | 12 | 01-03-2005 11:55 PM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
