Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 03-11-2008, 10:25 PM
Smitty911 is on a distinguished road
Saving Tool Tables
Well, I'm starting to get the hang of this.
Each time I go to cam something I have to start making the tools all over again.
Is there some way to once and for all save a tool table and just use it?
Smitty
Old 03-12-2008, 01:17 AM
metalworkz's Avatar
metalworkz is on a distinguished road
Hi Smitty,
You should be able to save the tools that are defined and give it a name so that each time you load your CAM program you can load that tool file. You can also set the preferences to load the toolfile automatically when the CAM program is loaded with several options of how to load. In CAM click View, then Preferences, then Options tab and select the option you prefer. You can also load the machine setup thru preferences in much the same way.
Regards,
Regards,
Wes
Old 03-12-2008, 10:23 AM
Dolphin USA's Avatar
Dolphin USA is on a distinguished road
Yes,
there are a couple of options.
In the Setup menu you have "Load Setup" and "Save Setup", these can be used to save the current machine setup (Tool change, Safe position etc) plus the current tooling to a .cfg file. When stating a new job simply select "Load Setup" and you have your tools and machine setup done for you.
Alternately from the View menu, select Preferences. Open the "Options" tab. Here you can select automatic saving and load toolfiles and machine setups.
Dolphin CAD/CAM Support
Download a free trial at
http://www.dolphincadcamusa.com
Old 03-12-2008, 12:00 PM
BrassBuilder is on a distinguished road
Thanks. I was having the same issue. I'll have to take a look at this tonite.
Mike
Old 03-12-2008, 03:06 PM
Not just me???
Mike
Thanks for the answer, and glad to know it's not just me. LOL
Smitty
Old 03-12-2008, 08:12 PM
Originally Posted by Dolphin USA View Post
Yes,
I cannot find these menus. I have the Intermediate version loaded if that makes a difference.
Smitty...did you find these in Setup?
Mike
Old 03-12-2008, 10:40 PM
Brassbuilder,
See attached file.
Old 03-12-2008, 10:52 PM
I only have these choices across the top in the CAM portion of the program:
File Edit View Execute Window Help
I looked in the toolbars to see if there was something I could activate to turn on the rest of them and I could not find anything.
Mike
Old 03-14-2008, 08:31 AM
Anyone have any ideas on this?
Mike
Old 03-14-2008, 08:37 AM
Brassbuilder, which Level do you own? 1 / 2 / 3?
  #11   Ban this user!
Old 03-14-2008, 09:47 AM
2
  #12   Ban this user!
Old 03-14-2008, 12:25 PM
BrassBuilder.. The reason it is only showing you limited options is because of Level 2. Level 3 unlocks all them for you.
Fagor 800T Tool saving tool set-up jime Fagor Automation 8 02-02-2009 07:53 AM
tool tables synv SolidCam 1 01-13-2008 11:56 AM
Tool Tables mmorton9 Mach Mill 2 01-17-2006 04:01 AM
Tool Tables mmorton9 Mach Software (ArtSoft software) 0 01-09-2006 05:01 PM
Tool tables Nimrod Mastercam 4 11-24-2003 02:31 PM
