Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 09-14-2007, 07:16 PM
BulleTxMagneT is on a distinguished road
Chamfering??
how do i have to setup my tool for this. it says my settings are incorrect. and when i do set them up and do lets just say a 3" square, it assigns the tool path to the center of the tool. i have a .25" dia 90 degree pointed chamfering tool and it is leaving a crazy burr from the point. is there a way to offset this so it is say .020" - .030" away from the center point of the tool?
thanks
Old 09-14-2007, 10:29 PM
well since no reply, i found a way to cheat it to make it work. i just made the tool .030 and had it cutter comp on the left or right depending on which way it was cammed, and then set my z to my liking of the finished part. wo0t
Old 09-14-2007, 11:47 PM
TZ250 is on a distinguished road
Tx, be careful about programming the cutter size too small. The tool is weak, has very little clearance and the surface speed is very low.
This is what I do:
For a .500" cutter, I program the size to .400" or so, then set the depth to .230". That will leave a .030" chamfer on a 45 degree cutter with a sharp point. (.400/2 = .200 + .030 = .230)
If you use a spot drill for chamfering, subtract .020"-.030" from the total depth because they are not ground to a sharp point.
Any source for an orbital action spindle??? rod chamfering? InspirationTool Mechanical Calculations/Engineering Design 3 06-04-2007 11:16 AM
Need help in chamfering abcdef General Metalwork Discussion 15 04-24-2007 07:34 PM
Chamfering at diffrent heights? turboboy OneCNC 2 11-29-2006 07:29 PM
need help with auto radius and chamfering dry run G-Code Programing 1 01-30-2005 03:52 AM
chamfering Mortek General Metal Working Machines 4 02-06-2004 10:24 PM
