Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 09-02-2007, 04:18 PM
BulleTxMagneT is on a distinguished road
Frustrated with Inch / MM garbage!!!
Part is drawn in Autocad as INCHES, import it into Partmaster Cam or CAD and it for some reason is converting the dimensions to MM and i can not find anywhere or option clicked on MM. Someone please help, Id like to make some chips today! thanks
Old 09-04-2007, 03:31 AM
MIKE JEFFERS is on a distinguished road
in part master goto view -properties -page set up choice of mm/inch
however the code generated will be in units -inch/mm/elephants etc
so if your mill is calibrated for inch 1.404 will be 1.404 inch
if set up in mm 1.404 will be 1.404 mm
go make something now
mike
Old 09-14-2007, 07:21 PM
thanks Mike J, that helped.
Old 09-17-2007, 03:11 AM
Smile
you're welcome
Frustrated beyond limits!! widgitmaster Mach Mill 35 12-15-2006 08:08 PM
Frustrated and venting charper CNCzone Club House 8 11-23-2006 11:56 AM
xp killer garbage update dertsap CNCzone Club House 17 04-30-2006 01:58 AM
I'm Lost & Frustrated - Need Help Hack Stepper Motors and Drives 14 12-09-2004 04:45 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 10:27 AM
