| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
| Help creating Passes with Goaround command? im using the goaround command so i can create tabs, not using the menu to the side to use contour. how do i make it create extra passes as opposed to one single cut? i could just be blind but is there an option? thank you |
| set cut depth in define tool i.e. 3mm for a sereis of 3mm deep passes |
| so if you define the tool as a certain depth you wont have to create extra passes in the options window of the contour as well? if so thats pretty cool. thanks |
| yup you tell it the tool wil cut in 2mm passes in cut depth in tool def then it will only cut a max of 2 mm in one go if your part is 1.5 mm thick it will cut at 1.5 mm even tho you give a cut depth of 2mm hope you understand that :-) |
| Both Conv/Climb Passes on Line Art | MichaelHenry | SprutCAM | 9 | 09-04-2007 10:16 AM |
| Lazycam doesn't generate "passes" | wadero | Mach Mill | 10 | 08-21-2007 05:22 PM |
| what is the same command? | hop | G-Code Programing | 0 | 06-20-2006 06:24 AM |
| how to change the passes in turning | joachim | FeatureCAM CAD/CAM | 0 | 02-17-2006 01:26 PM |
| Milling: low depth passes or all the width? | PEU | DIY-CNC Router Table Machines | 8 | 11-02-2005 06:57 PM |
