Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 08-16-2007, 09:13 PM
metalworkz's Avatar
metalworkz is on a distinguished road
2d Tabs on contour to hold part in blank
Is there an easy way to do 2D part tabbing in PartMaster? For example when doing the final oustside contour on an aluminum part .125 thick is there an easy method to tab the part into the blank so it doesn't move when the contour is finished. I am familiar with tabbing of parts for laser and punching operations but wanted to know if there is a machining method within the program or will I have to break up the contour and program it so it will have tabs to hold the part? Thanks in advance for any suggestions or help.
Wes
Old 08-17-2007, 04:33 AM
MIKE JEFFERS is on a distinguished road
usually just foil ,it for a .125 thick part cut .120/.122 then deburr
but using partial machining(options tab) allows you to sort of create tabs
other than that do it at the cad stage
mike
Old 08-17-2007, 07:24 AM
Chad_Clark is on a distinguished road
Wes
Wes,
Is this on the milling module or the wire edm module?
Old 08-17-2007, 11:35 AM
BulleTxMagneT is on a distinguished road
milling module.
Old 08-17-2007, 08:54 PM
metalworkz's Avatar
Hi Chad,
It is on the milling module.
I wanted to see if there is an easy method in the program to hold the part in the blank for example with tabs or micro joints similar to the way parts are tabbed into a sheet for laser and punch work. The small tabs or micro joints (like at 4 corners .020-.030 tabs) hold the part and blank together and make for easy punching or lasering of multi-part blanks. I figured I could break up the contour in the CAD stage and create the tabs where needed but it would sure save some time on the programming end if the software had an option to do this for you.
For small parts it would be great if there is a way to nest them and run multiple parts but I will need to implement a method of holding the parts together on the blank to make this feasable.
Thanks Mike Jeffers for the partial machining foil suggestion.
I just wanted to say I am very pleased with the results I have already had with the Dolphin PartMaster program!
Wes
Old 08-20-2007, 07:59 AM
Wes,
I will email a couple videos I had created that shows how you do this in the milling module of the software.
P.S. If there is anyone else that would like these please let me know so that I can email them to you.
Old 08-20-2007, 05:50 PM
metalworkz's Avatar
Hi Chad,
Thanks for the videos on bridging contours! It looks like exactly what I wanted for an option to add tabs where needed without doing extensive redrawing at the CAD stages. This will save us a lot of time and provide a better way to keep parts and multi-part blanks together in the blank.
Best regards,
Wes
Old 08-23-2007, 01:38 AM
r.r.mccoy is on a distinguished road
Hi Chad
I'd like to see the videos.
Best Regards,
Roy
Old 08-23-2007, 08:21 AM
Originally Posted by r.r.mccoy View Post
Hi Chad
Best Regards,
Roy
Sent Videos to email this morning Roy.
Old 08-23-2007, 08:53 AM
I have found that a lot of emails won't accept the file size that the videos are. So I have put the videos under the support page on my website. Below is a link to that page.
http://dolphincadcamusa.com/Support.html
  #11   Ban this user!
Old 08-24-2007, 02:35 AM
Thanks for the videos Chad.
The downloads worked just fine.
These videos you guys produce sure make things easy to understand.
G-Code for holding tabs mikemill General CAM Discussion 6 06-05-2007 07:38 AM
Problem using tabs LongRat SheetCam 4 08-06-2006 04:39 AM
TL-1 Missing Tabs elaganis Haas Mills 2 06-19-2006 01:24 PM
Adding Tabs With MasterCam V9 mmcclain02 Mastercam 5 01-20-2006 02:53 PM
Tabs in V9 MikeA Mastercam 13 03-20-2004 06:55 PM
