Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 06-11-2007, 09:50 PM
TZ250 is on a distinguished road
Updating An Old Drawing
Guys, what is the best way to update an old drawing?
When I open an old drawing to make a change, I have to re-establish a datum. Basically, the computer is viewing that as a print.
I can click on the original datum, but I don't know how far I'm off. There must be a better way.
Thanks again,
Rob
Old 06-12-2007, 04:30 AM
MIKE JEFFERS is on a distinguished road
i usually make the datum a circle someware then it is a recognisable contour
therefore you can use snap to locate it confidently
but i'm shure this is what you already do
own a few yam strokers meself (if it's the same tz250)
mike
Old 06-12-2007, 11:50 AM
Chad_Clark is on a distinguished road
Are you reopening a .dra file, if so the datum shouldn't be changing. I have tested this and it hasn't moved?
Old 06-12-2007, 12:27 PM
After talking to you on the phone I did some testing on the temp. files and I found out that the datum stays the same in there too, as they are just .dra files also. When you change the datum are you using the blue datum toolbar button or the red one? I will help you figure this out.
Drawing help dwacker Dolphin CADCAM 11 05-08-2007 04:53 PM
Fanuc code needs updating. Roberts General CNC (Mill and Lathe) Control Software (NC) 15 02-21-2006 08:45 PM
Drawing ? Ken_Shea OneCNC 4 06-08-2003 11:54 PM
Precaution when updating OnecncXP HuFlungDung OneCNC 1 06-03-2003 11:23 AM
