Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Dolphin CADCAM
Dolphin CADCAM Discuss Dolphin CAD/CAM software here.
Old 06-06-2007, 06:32 PM
TZ250 is on a distinguished road
Drawing & Template Help Needed
Is it possible to import a drawing file into a template?
I've made a drawing of a part. I don't want to send it to the customer without the title block.
I know, I should have started with the template to begin with. You know the old adage "Hind sight is 20/20".
Thanks once again.
Old 06-07-2007, 01:04 PM
Chad_Clark is on a distinguished road
There are two methods :-
1) Use SELECT / COPY / PASTE between two .dra files.
2) Use Symbol method i.e.
Collect Drawing Area as Symbol, this will be saved as a
separate Symbol File.
Recall Drawing and load Symbol.
Old 06-07-2007, 04:41 PM
Mr. Clark, please explain this in greater detail.
'Copy' is greyed out and is not available. Paste works, but I haven't copied anything yet.
I've tried lots of combinations of 'Symboll. Nothing has worked so far.
The help file is almost useless. It tells what something is, but not how to use it.
To make matters worse, the program crashed three times while trying to make this simple change.
Old 06-07-2007, 10:43 PM
For #1
You have to select your drawing first and then copy will light up. You can do this by using "Select All" under the "Edit" menu. Then choose copy and then go to the template with the title block you want to use and select "Paste" under the "Edit" menu. You will then be able to place the drawing where ever you want on the screen with in the title block. I hope this helps.
Old 06-08-2007, 03:42 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I had a similar problem ages ago- select everything and make it into a block. - Copy the block or save the block (sorry cant remember which). Open up your template. Paste or Insert the block you made- select it and explode it.
I love deadlines- I like the whooshing sound they make as they fly by.
Template Bulider Tazzer Haas Visual Quick Code 9 02-18-2008 03:24 PM
CNC Setup Template MartinLogan General CNC (Mill and Lathe) Control Software (NC) 1 03-20-2007 06:02 AM
drawing needed 1cnchogger General CAM Discussion 3 02-06-2007 07:18 PM
VQC Template Builder leggetmachine Haas Mills 3 05-28-2006 08:00 PM
