Results 1 to 2 of 2
Thread: Mach 3 Tool Tables?
    Jun 2004
    Mach 3 Tool Tables?
    Is there a way to edit the post processor files? I used to use the mach3_peck or mach_4 rotary files until I started having problems with arcs. I then switched to a mach3_inc post processor but that one doesn't seem to apply the mach 3 tool table offsets.
    mach3_inc only creates a line like this for the tool change:
    N 60 M06 T03
    whereas the mach3_rotary post processor creates the following lines:
    N7T3M06 ( 1/4" 3-Flute Radius End Mill )
    N8G00G43Z0.1H3
    And if I understand correctly, the 2nd line is what is important in order to tell mach3 to use the offsets. There are no G43 commands in the _inc processor.
    Jun 2004
    I should have researched a little more. I figured out how to edit the _inc post processor and add the G43. Works great now.
  1. tool tables
    By synv in forum SolidCam
    Last Post: 01-13-2008, 12:56 PM
  2. Mach 3 and router tables???
    By bgriggs in forum Machines running Mach Software
    Last Post: 10-22-2007, 12:33 AM
  3. Tool Tables
    By mmorton9 in forum Mach Mill
    Last Post: 01-17-2006, 05:01 AM
  4. Tool Tables
    By mmorton9 in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 06:01 PM
  5. Tool tables
    By Nimrod in forum Mastercam
    Last Post: 11-24-2003, 03:31 PM
