| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
Running a new Partmaster Vs 10.0.1006 I cannot find the Attribute Menu which is mentioned in the manual. Has anyone else had this problem? Is it a feature of the model or finger troubloe on my part? I would like to use it if possible. Any help welcomed. |
| Hello, Attributes are basically pieces of text added to a drawing which can then modified when the drawing is opened. The main use of attributes is to create things like Drawn By: xxxx Date: xxxx etc on a drawing when it is created and opened as a Template. Firstly go to Draw > Attributes from the main menu. Create the attributes as required. Save As.. a Template. Open the Template and you will be prompted to change the value of the attribute. Open the _default template by using the Icon in the top left corner - it has the down arrow next to the paper icon, you will be prompted with a box where you can change the Value of the attributes. Hope this is clear. ATB Andre |
| "NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN" | CNCadmin | EBAY ADS | 0 | 11-06-2011 01:00 AM |
| Heidenhain "Angle Reference Missing" error | Lugy | General CNC (Mill and Lathe) Control Software (NC) | 0 | 05-10-2011 02:07 PM |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| "J" head type "millport"(tiwan,1980) clutch | marksbug | Bridgeport and Hardinge Mills | 1 | 08-17-2009 10:48 AM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
