| Dolphin CADCAM Discuss Dolphin CAD/CAM software here. |
I´ve just finished retrofitting a Boxford 280 Turnmaster lathe with USBCNC CPU5B professional from Bert Eding (Eding CNC - PC based CNC control). I´ve bought Partmaster Lathe cam from Dolphin. Do anyone here know what Postprocessor to use? |
| Peter, Other than suggesting the Mach driver I can't help but I'd be interested to know how it works out as regards threading. Mach, using the parallel port is useless. many who say they don't have a problem do have but they don't do long enough threads for it to be apparent. John S. |
I´m beginning to modify the Mach postprocessor, but I´m a newbie to lathe postprocessor, so I´m afraid of making mistakes. I´m done with the groups. Can you se if I´m doing right so far? I´ll try to attach a copy. I have tried to make a simple job of turning an arc, but when I load it into USBCNC it tells me: Radius of end of arc differs from radius to start. Regarding treadcutting I have not tryed it yet, but I have a sensor on my spindel, and I understand that it syncronise the startpoint of treadmaking (G76 in USBCNC). Is it very expensive to get a customised postprocessor? Regards Peter |
| I think the problem with the arcs is a question of the centre coordinates being either incremental or absolute. Can you change the setting in USBCNC ? if not the post can changed. The standard Fanuc post - T_F0TC, uses incremental - have a look to see the difference between under the macro section, here is the entry #I = { (($YCEN-$OLDY)/2):XARC } Absolute would be #I = { $XCEN:XARC } Hope this helps. ATB Andre |
hi Peter Nielsen, I am also using USB CPU V5 by eding cnc for my CNC Plasma/oxy fuel Combo with spendel on it, i also use sheetcam for converting my cad drawing to g-code and i am using the EMC plasma processor. Also if you use this on cnc lathe try the EMC, but i am not sure if it work. Please send me a feed back what happen because i am also planning to build one of cnc lathe using USB CPU. Thanks |
| USBCNC CPU V4 | Web Goblin | Controller Cards | 1 | 05-23-2012 11:23 AM |
| Eding USBCNC | Web Goblin | General CNC (Mill and Lathe) Control Software (NC) | 8 | 04-12-2012 12:20 AM |
| almotion usbcnc | the evil E | Haas Mills | 1 | 11-24-2010 04:40 PM |
| Vectric-PPs for USBCNC | elses | Post Processors | 1 | 11-04-2009 04:24 PM |
| postprocessor for USBCNC | Blerbaby | EdgeCam | 3 | 10-29-2009 06:25 AM |
